no spark
Old May 13, 2011 | 10:01 PM
cncquinn's Avatar
Default no spark
Hey guys, new on here. Well here's my story. i have a 98 f3 that has no spark. A couple years ago I had it running, went outta town for the weekend, and when i came back I started the bike and let it warm up. When i got on and put it in first it slowly died. I checked the plugs and i had no spark, got new plugs and nothing, same problem, If anyone has an idea of what went wrong, let me know. I really dont wanna pay a shop 80 bucks an hour to tell me it might be something simple i could have done. thanx
Old May 13, 2011 | 11:06 PM
kerosene's Avatar
Have you checked the ignitors to make sure they're connected?
Old May 14, 2011 | 12:30 AM
9-5=4rr's Avatar
^^^ +1 to that .... and I also would personally be checkin out the timing pulse generator sensor ... I couldn't see all your plugs and coils going out at the same time :\ ...
Old May 14, 2011 | 08:48 AM
Originally Posted by cncquinn
... A couple years ago I had it running, went outta town for the weekend, and when i came back I started the bike and let it warm up. When i got on and put it in first it slowly died. I checked the plugs and i had no spark, got new plugs and nothing, same problem....
Am I reading this right ? The bike hasn't been running for a couple of years ? If so, then I'm thinking battery and carburetor cleaning, fresh gas and whatnot. Have you been riding it since then (a couple years ago)?
Old May 14, 2011 | 09:47 AM
cncquinn's Avatar
the bike broke and i then it sat. i took the gas out before it sat. when i was trying to get it running a couple years ago the batt. was good, but it might be bad now, the carb. was cleaned a couple years ago
Old May 19, 2011 | 05:44 PM
cncquinn's Avatar
Default no spark
I'm also being told by others that have cbr's that i should check my fuse boxes, the problem is that i can only find 1 and thats by the right handle. They say i have another one but no one seems to know where it is. If anyone can tell me where it is that would help me out
Old May 20, 2011 | 09:30 PM
cncquinn's Avatar
hey thanx, all i did was pull the ignitor and plugged it back in and she fired right up
Old May 21, 2011 | 02:51 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
if shes been sitting for a few years, there might be a few things I would personally do before I hit the road again, but that's just me:
flush the rad.
new dot4 brake fluid.
new gas.
run seafoam through it.
new oil.
new filter.
new battery/trickle charge it back to 13v
air in tires/new tires depending.
also, not a huge issue usually, but new brakes if the condition was bad (clean with 2.00 brake cleaner from walmart)
Old May 21, 2011 | 11:52 AM
cncquinn's Avatar
flush the rad.
new gas.
new oil.
new filter.
I did the oil gas and new batt. already, i plan on seafoaming, would i put that in the gas tank, cuz when i seafoam my truck i put it in the vaccum line, and how much would you suggest i use
Old May 21, 2011 | 04:55 PM
i think it says the amount on the bottle
1 bottle treats 25galon,
about a quarter of a bottle per tank is what i use.
baseballkid
Oct 4, 2012 07:48 AM
jaredaamy
Jan 1, 2009 10:51 PM
Bazman
Nov 23, 2008 01:13 AM
w4kr
Jun 11, 2007 04:44 PM
rideitnaked
Jun 10, 2007 12:32 AM
