will a slipon fit on race header?
Old Sep 19, 2013 | 03:10 PM
itsahurricane's Avatar
Default will a slipon fit on race header?
I have a 94 f2. It has the full vance and hines ss2r exhaust. I really like the danoto xg1 but its a slipon. They said it will only go on a oem header.. just wondering what's different. the diameter or length?
Old Sep 19, 2013 | 03:27 PM
Ls1Mx5's Avatar
I'm wondering the same thing, but more so because I have a slip on from a race header I want to put on a stock header. Maybe someone can help us out here
Old Sep 19, 2013 | 03:34 PM
gtcole's Avatar
Welcome Crew
I'm not too sure honestly as I only have OEM with a yosh slip on. But I would assume that it would be diameter
Old Sep 20, 2013 | 10:10 PM
squale147's Avatar
July 2013 ROTM
i just checked for you guys ..stock header outlet OD is 48.5MM and the ID is 45.9... hope this helps
Old Sep 20, 2013 | 11:32 PM
CJardine's Avatar
Track junkie & modaholic
Normally you cannot put a different midpipe on a set of aftermarket headers as the outlet diameter rarely matches the OEM, also you need to make sure that exit angles are the same between the two headers. now what you can do is replace the can, little known fact (for some reason) the cans are - for all intents and purposes - are universal; the only things that need to match are the position (normally does because of the mounting point) and the outlet of the midpipe and the inlet of the can. case in point, I have a Jardine can with micron headers /midpipe, the outlet of the midpipe is 2 1/4" and the inlet of the Jardine can is 2 1/4" everything matched up. Hope it helps.
Old Sep 21, 2013 | 10:02 AM
Ls1Mx5's Avatar
Thank you
Thanks for the info
Ls1Mx5
Oct 9, 2013 09:06 PM
gw7
Feb 28, 2012 09:22 PM
darkness954
Jul 17, 2008 11:34 AM
