More electrical problems!
Old Oct 25, 2011 | 07:47 AM
JankCibberf2's Avatar
Default More electrical problems!
Hey yall, i was wondering what is happening with the bike now. I already swapped the r/r over the summer to make this thing happy and it worked for the entire riding season. Now i'm pushing it riding into this cold *** fall dropping into like the 40s i really don't want to garage the bike just yet.
On to the problem, the battery is dead, i can't figure out why. at first i was wondering if it was the stator, however, if the stator decided to poo out would the bike decide to stop running after it was jumped? we push started it and i was able to ride like another 70miles. However, i have no idea how these honda's electrical system work so im not sure whats going on.
Secondly, i read on the forum a crappy side stand switch can also cause the bike to misfire at high revs, is that true?
Anyways, im just wondering if i have a chance of a bad battery, or bad stator. Thx guys
Old Oct 25, 2011 | 09:16 AM
74demon's Avatar
sounds like it could be a bad battery. how old is your battery? the only way to be sure is to take voltage readings on the battery and charging system. charge the battery then load test it. replace if necessary and take a charging system reading.
Old Oct 25, 2011 | 10:37 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Try these two links:
Motorcycle Charging System Troubleshooting Chart
Motorcycle Electrical Diagnosis
Old Oct 25, 2011 | 10:58 AM
hopefully its a bad battery, the battery is i think about 4 months old however, i bought the battery before i bought the rectifier so i don't know if the bad rectifier killed the battery but its on the charger now at autozone so they'll test it once its done for me as well
Old Oct 25, 2011 | 11:57 AM
RoadiJeff's Avatar
I hope Autozone knows not to use the same charging rate as they do on a regular car battery or if your little motorcycle battery wasn't already bad it will be now.
Old Oct 25, 2011 | 12:12 PM
JesseAwesome's Avatar
This stuff is ultra easy to troubleshoot with a $9 multimeter from harbor freight.
Old Oct 25, 2011 | 02:48 PM
lol i used to work there and hooked it up to the trickle charger. now with a multimeter (which i need to buy) is it super hard to do? im afraid of electrical problems!
Old Oct 25, 2011 | 02:58 PM
74demon's Avatar
super easy. red to +, black to -. (on battery) read voltage. 12.8v off, 13.5v to 14.5v running at rpm. tell us what you get. that will show where to look next.
Old Oct 25, 2011 | 06:26 PM
sounds good, just got the battery back, took a charge and tested good... soooo dang lol
Old Oct 25, 2011 | 11:41 PM
well for the update, car threw a cel so i got pissed, had no intention of working on the bike today but because of that i wanted to hop on the fastest thing i had, which was the moty lol. Anyways, checked the r/r and man was it a pita to pull the harness out, it was like glued in there. the harness was burnt from the last r/r going bad but the new one was pretty clean with a small looking meltedness on one of the metal prongs. but the battery in, and she fired right up, idled fine, and then i went and played wheelie time lol, so i'll post pics of the r/r as well as keep this updated to see if the battery dies in like a day
dcaldwell
Oct 6, 2009 10:20 PM
thetrick13
Aug 11, 2009 10:13 AM
f3gatorfan3388
Nov 19, 2007 02:28 PM
rblevins4130
Nov 10, 2007 04:36 PM
dizzie56
Jul 9, 2006 01:59 AM
