Just back from ride that was very frustrating
All it takes is the smallest of particles, or minor blockage to cause you headaches. If your one to clean ur carbs once a year and keep a clean air filter you wont usually have any issues with carburation. But if you are one to run er till she she gives you problems, i like to fully break the carbs down and soak them good. If you take your time reassembling your carbs and give them a CAREFULL bench sync, you would be suprized in the results. Try to use a dielectric grease at all the o-rings incuding the intake boots and float bowl gaskets (use sparingly). Ive truley never had to use the mercury sticks after a carfull bench sync either. i've hooked them up and checked them after doing this and was off on # 4 by not even an 1/8 turn Syncing, really only gets them close anyhow. if you want it perfect buy a fuel injected bike. youll likely not notice the inperfection. To me, thats what makes carbs a science, and fun!
mario_r34
06-01-2010 04:24 PM
