i can't shift into neutral
Old 09-15-2010, 04:31 PM
McSpreadum's Avatar
thank you all for trouble shooting with we by the way
Old 09-16-2010, 01:35 PM
gpfan1's Avatar
If you look at the stopper arm, it should have a spring that pulls it against the cam. Is the spring there and is the wheel on the arm in good shape? Can you manually change gears and observe the cam/stopper in action?
The spring on the arm and the arm are popular items to upgrade. The upgrade is a better bearing stopper arm and a heavier spring to keep the arm from bouncing out during hard shifts. could be that your spring is cracked or weakened.
How many miles have you put on the bike?
Old 09-21-2010, 05:16 PM
McSpreadum's Avatar
that is exactly what i was thinking. thank you so much. you hit the nail on the head. worked like a charm. thanks again
BalizTik
08-29-2013 11:01 AM
cortlandboy
07-15-2013 10:05 AM
amacadams
08-19-2011 04:13 AM
wehereerrere84
08-31-2007 09:54 PM
oliversta
09-16-2006 09:28 AM
Quick Reply: i can't shift into neutral
