94 CBR F2 wont shift out of neutral
Old Jul 12, 2013 | 08:31 PM
cortlandboy's Avatar
New Member
Default 94 CBR F2 wont shift out of neutral
Hi everyone Im new to this forum thing and im sorry if i missed a thread on this topic, but I have a 94 CBR 600 F2 that just got a new clutch kit installed and it drove fine but now if will not shift out of neutral. I would like to thank you all for the help.
Old Jul 12, 2013 | 08:53 PM
BorntoRideUSMC's Avatar
New Member
Ive had the same problem. all i did was hold in the clutch and rock the bike really hard backwards and forwards. that should free it up and you should be able to kick it into neutral afterwards. not sure why it happens but thats just a quick fix if it happens again.
Old Jul 15, 2013 | 06:36 AM
Duck62's Avatar
You need to check your installation of the clutch. The order of installation is very important. You should also measure the pack and be sure it is in spec.
Old Jul 15, 2013 | 10:05 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
I am assuming that you verified your clutch cable adjustment? If you got it in the proper place originally, and failed to tighten the lock nuts for the cable, things might have vibrated/shifted to where you're not getting proper engagement/disengagement of the clutch.
Other than that, like Duck said, you'll have to re-check your installation, and verify your plate stack is correct.
Did you torque all the bolts to spec?
BalizTik
Aug 29, 2013 11:01 AM
amacadams
Aug 19, 2011 04:13 AM
McSpreadum
F2 Tech
Sep 21, 2010 05:16 PM
wehereerrere84
Aug 31, 2007 09:54 PM
oliversta
Sep 16, 2006 09:28 AM
