Fuel and vacuum problems! Please help!
Old May 21, 2011 | 07:54 PM
Z28F2's Avatar
Originally Posted by damuho
The solenoid sounds more like a valve from the way you are describing it. The previous owner may be having some issues with fuel delivery and decided to use a switch-controlled valve to let fuel flow to the carbs. Since the vacuum from carb #1 is no longer needed, he plugged the hose with a bolt.
No its the factory solenoid that all of the vacuum lines go to! And it did still need that tank hose, the dumbass just didn't know what he was doing and the factory hose was burnt and he found that was where it was leaking vacuum pressure and just put a bolt in it like a moron!
Old May 21, 2011 | 07:56 PM
Z28F2's Avatar
Originally Posted by Monkeybutt2000
So the 2 nipples on the bottom of the fuel tank,what connects to them? Hoses that just vent to atmosphere?
Im not to sure which nipples you are refferring to! The petcock fuel nipple is going to the main fuel line and the vacuum nipple was going to the atmosphere but is now going to carb #1 like it is supposed to!
Old May 21, 2011 | 09:33 PM
Monkeybutt2000's Avatar
Ok,I know the larger line is the fuel feed from the carb. The smaller nipple on the petcock connects to the nipple on the left side of the engine for vacumn for the shuttle valve to operate. There are two nipples on the bottom of the metal tank itself. I'm pretty sure these just vent to atmosphere.
Old May 21, 2011 | 11:31 PM
Z28F2's Avatar
There aren't any other nipples on the bottom of my tank except the main fuel and carb vacuum line.
Old May 22, 2011 | 12:55 AM
damuho's Avatar
I think he is talking about the two vents near the back of the tank (not the petcock). There should be hoses connected to them and these hoses are routed towards the ground.
Old May 22, 2011 | 10:04 PM
Exactly what I needed to know,thanks.
Old May 23, 2011 | 01:06 AM
Z28F2's Avatar
Yeah I think my tank is not the factory one b/c it doesn't have any other nipples on the bottom. Also, does anyone know where I can get a locking gas cap? I've been searching, but haven't found one yet. Mine just has a push and twist cap.
DonnyBrago
Jan 26, 2011 02:03 PM
PhilDawson8270
F2 Tech
Sep 18, 2010 12:26 AM
pablohoney
The Hurricane Saloon
13
Sep 9, 2009 09:34 PM
puma690
Mar 6, 2009 03:01 PM
GuywithF4i
Jul 9, 2007 06:37 PM
