Fried the alternator wires!
Old Mar 10, 2013 | 09:37 PM
Ls1Mx5's Avatar
Default Fried the alternator wires!
So I trickle charged my battery while it was still in the bike today as I have in the past without issue. I removed the charger, started her up and soon smelled something burning. The source of the smell was the 3 pin alternator plug that connects the 3 yellow alt wires to the rectifier wires. The plug itself had melted and the wires started fusing together.
What did I do to my bike? Anyone have thoughts? Thanks
Old Mar 10, 2013 | 10:23 PM
tucsondude's Avatar
I noticed that connector melted on me when i was replacing the rectifier. are you still running the factory rectifier? if so, and its bad go aftermarket.
Old Mar 10, 2013 | 11:09 PM
Ls1Mx5's Avatar
Your connecter fried before you replaced it then? And why aftermarket and not a stock rectifier?
Old Mar 11, 2013 | 01:51 PM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
The failure of the stock R/R is one of the "common issues" with the F2 - because of it's design (lack of cooling fins on the heat sink), it overheats quickly.
If you go to Honda now, and buy an OEM replacement, it is different than the original, and supposedly, with the new part, the issue has been addressed, but I have never seen the new part... most guys go with aftermarket, or a "swappable" unit from a GSXR or R1.
I'm at about 27K or so on my first F2, and I'm still running the original part with no issues, but I know a lot of guys have had to replace it.
Old Mar 11, 2013 | 01:58 PM
underground-mpyre's Avatar
I agree with JNS, it is a downward spiral from the Stator, Rectifier and sometimes leads to a dead cell in the battery. As JNS said replace the R/R and Stator.
Old Mar 11, 2013 | 02:21 PM
Ls1Mx5's Avatar
Thanks guys, yea I figured as much, I ordered one on eBay new for 20 bucks. Do I really need a new stator though?
Old Mar 11, 2013 | 02:54 PM
JNSRacing's Avatar
You found an R/R, new, for $20?!? Did they make it out of tin foil??
Seriously though, that is beyond cheap - unless the seller bought a new one, never ended up needing it, and is now just trying to unload it, I would be concerned about the quality of a $20 R/R!
As for the stator, test it. I see no reason that you should replace the stator, unless it doesn't test out ok... there's diagnostic parameters for this in the manual.
Old Mar 11, 2013 | 08:55 PM
tucsondude's Avatar
Read this thread stickied above. note my post
https://cbrforum.com/forum/f2-tech-9...d-27739/page9/
hmm
Aug 28, 2013 07:21 AM
hmm
Jul 17, 2013 05:22 PM
hard2obtain
Mar 9, 2011 10:53 PM
91F2 project bike
F2 Tech
Jul 8, 2010 09:54 AM
kmboll
Apr 4, 2008 08:08 AM
