CCT Replacement (fix the engine rattle for good)
Old Jul 16, 2009 | 10:04 PM
  #21
1down's Avatar
Is this noise only at idle? I have a simular noise on cold start up goes away when you raise the rpm's haven't noticed any running or performance issues.
Old Jul 16, 2009 | 11:31 PM
  #22
Sand.Man's Avatar
As RPM's pick up, so does oil pressure slightly... It's likely your CCT.
Old Jul 17, 2009 | 12:28 PM
  #23
sleepercbr's Avatar
i think i have the same problem but i just recently had it change by a mechanic 3000 miles ago which he recommended but never heard any noice. now 3000 miles later im hearing this rattling noise at low rpm or when i down shift. could it be my tensioner is bad at only 3000 miles???????
Old Jul 17, 2009 | 12:52 PM
  #24
Sand.Man's Avatar
If it's a hydraulic tensioner yes, they are useless.
Old Jul 17, 2009 | 01:44 PM
  #25
sleepercbr's Avatar
Default chain tensioner install
what other gaskets should i buy before installing the new cam chain tensioner. and do i remove the right engine cover????????????????????????
Old Jul 17, 2009 | 02:58 PM
  #26
Sand.Man's Avatar
None, no need to remove anything from the engine aside from the CCT.
Old Jul 17, 2009 | 03:39 PM
  #27
sleepercbr's Avatar
what other gasket do i need to buy before installing a new cam chain tensioner?????????????????????????
Old Jul 17, 2009 | 05:33 PM
  #28
Sand.Man's Avatar
D-d-d-d-did I studder?
Old Jul 17, 2009 | 06:45 PM
  #29
Dissevered's Avatar
lol
Old Jul 22, 2009 | 10:45 AM
  #30
Chymera14's Avatar
So I take it everyone is pretty pro APE... I just changed out the old for a replacement OEM and after about 200 mi it is back at it again. Are there any other brands than the APE that are better, worse, ect.?? The rattle makes me concerned about ridding it even though from what I have read it doesn't seem to be too big a deal other than an annoyance.
