tighten your header bolts people!
Old Jan 13, 2011 | 10:46 AM
moosestang's Avatar
Default tighten your header bolts people!
My eyes started burning while checking for oil leaks with the bike running (changing oil, fairing off). Checked all the header bolts and only 2 were torqued to spec according to my torque wrench (9lb ft). 2 were ready to fall out. Now I have to go and check all the bolts/nuts on the bike.
That brings me to another question. Does the purolator filter actually seal on this bike? Mine was weeping a little bit after a 100 mile ride, so I gave it another He-man turn. I noticed the honda filter has an oring type seal and the purolator doesn't.
Old Jan 13, 2011 | 11:06 AM
Conrice's Avatar
your oil filter should definitely seal....
i've used k&n, honda, hiflofiltro, and fram, and all of them have had an o-ring seal, so i don't know what the deal is with your purolator
Old Jan 13, 2011 | 11:41 AM
moosestang's Avatar
It has a flat rubber gasket like most car filters. The honda filter has a rounded oring gasket.
I just checked it and it didn't leak. Must have needed one more turn. I'll keep my eye on it and probably use a k&n next time, if I can find it.
Old Jan 13, 2011 | 11:44 AM
Kuroshio's Avatar
If you don't have a torque wrench and oil filter cap attachment, rule of thumb is generally hand tight + 1/4 turn more.
Old Jan 13, 2011 | 01:16 PM
Conrice's Avatar
oh, okay, still, haven't really ever seen an oil filter for the bike that doesn't have the o-ring. but hey, if it's not leakin', then you should be good to go. ride on
playb0i
Jun 2, 2009 08:46 AM
turboryan
Apr 24, 2009 02:01 PM
ForcedInduction
Mar 10, 2008 06:31 PM
axsys
Nov 30, 2007 01:47 AM
whiteknight
Jun 22, 2007 02:14 PM
