tighten your header bolts people!
My eyes started burning while checking for oil leaks with the bike running (changing oil, fairing off). Checked all the header bolts and only 2 were torqued to spec according to my torque wrench (9lb ft). 2 were ready to fall out. Now I have to go and check all the bolts/nuts on the bike.
That brings me to another question. Does the purolator filter actually seal on this bike? Mine was weeping a little bit after a 100 mile ride, so I gave it another He-man turn. I noticed the honda filter has an oring type seal and the purolator doesn't. |
your oil filter should definitely seal....
i've used k&n, honda, hiflofiltro, and fram, and all of them have had an o-ring seal, so i don't know what the deal is with your purolator |
Originally Posted by Conrice
(Post 1004213)
i've used k&n, honda, hiflofiltro, and fram, and all of them have had an o-ring seal, so i don't know what the deal is with your purolator I just checked it and it didn't leak. Must have needed one more turn. I'll keep my eye on it and probably use a k&n next time, if I can find it. |
If you don't have a torque wrench and oil filter cap attachment, rule of thumb is generally hand tight + 1/4 turn more.
Originally Posted by moosestang
(Post 1004219)
It has a flat rubber gasket like most car filters. The honda filter has a rounded oring gasket.
