Port and polish Advice
Old Feb 19, 2013 | 07:35 AM
mrsmobbins101's Avatar
Default Port and polish Advice
Well its as simple as that. I still havent had my head port and polished for my engine rebuild and am looking for somewhere that is confident enough to do it, maybee even known for it. Any help would be great. Thanks
Old Feb 19, 2013 | 09:19 AM
Conrice's Avatar
APE could do it.
cooper performance - they're known for racing bikes (drag and short circuit). that's who i was planning on using.
call them. talk to them. tell them what you want and see what they say
Old Mar 9, 2013 | 04:29 AM
mika_u's Avatar
Sept 2014 ROTM
If your using aftermarket cams the head porting is a must do thing. The porting alone has gain 12 hp to rear wheel in this bike whit oem cams:
HPS Honda CBR900RR 954 Fireblade
Here is a graph of oem 954 head compered to unfinished ported 954 head. You will have to download it. It's a .pdf. Here is a link to fireblades.org
CBR 954 main and rod bearing help? - Page 3 - Honda Motorcycles - FireBlades.org
Couldn't attach it here. The professional that ported/ports my head said the oem heads flow is dead( stops increasing) at 8.3 mm of lift so my grinded cams would probably be worth 4-5 hp whitout the porting. Even the oem intake cam have 8.7 mm valve lift so you won't get everything out of it whit oem head. Only thing whit the porting is that it will probably move the peak hp rpm range up and even 954:s whit full exhaust will make peak hp very close to limiter.
woodypk
Mar 23, 2011 03:05 AM
rdeaner
Oct 6, 2010 03:14 PM
1iwilly
Oct 6, 2009 08:48 PM
FLYOU
Dec 6, 2007 10:33 PM
layinlow
May 30, 2007 04:42 PM
