Oil Filter
Old Jun 13, 2006 | 05:24 PM
surfercc's Avatar
Default Oil Filter
You guys buy the Honda OEM oil filter? Or do you get a FRAM, etc that fits the threads/size of the OEM filter? I found a FRAM that's about a third of the price of the Honda filter, but is there any difference in the size of the mesh filters within that filters the oil better between the two???
Old Jun 14, 2006 | 12:32 AM
mjb954rr's Avatar
Default RE: Oil Filter
I used to run the Fram but have heard bad things about them. I have since switched to a purolator ML16817. You can find these at pepboys for around $5. Im not sure what you are running for oil, but after a lot of reading and research I switched to Shell Rotella 5w40 synthetic. $14 a gallon at walmart. It amazed me how much smoother the engine runs with this oil. Matt
Old Jun 14, 2006 | 01:53 AM
bobjoezx's Avatar
i use the K&N love the nut at the end for easy on and removal and a great filter
Old Jun 14, 2006 | 01:49 PM
matt365's Avatar
A company called "Hi-Flo" makes the factory Honda filters. Hi-flo also has their own filters, made to the same honda specs without the honda name... alot cheaper for the same product.
http://www.hiflofiltro.com/
Old Jun 14, 2006 | 06:53 PM
driber's Avatar
i run a fram and have never had a problem. it is fram PH6607 for a 954.
Old Jun 15, 2006 | 11:10 AM
surfercc's Avatar
Thanks a lot. I didn't want to be buying the honda name everytime i change my oil when I knew other filters would fit on the bike
Old Jun 15, 2006 | 09:01 PM
driber's Avatar
yeah i change my oil/filter sometimes twice a month. I change it every time i come back from the race track. So at less then $5 a filter i save some $$ compared to the $15 filter from the dealership. And it holds up just fine for me.
Old Jun 15, 2006 | 11:07 PM
mjb954rr's Avatar
The Fram model i used was a 6017A on a 954
Old Jun 15, 2006 | 11:27 PM
driber's Avatar
yeah that is NOT the right filter. here is the link for the fram website :
http://www.fram.com/pdf/Motorcycle.pdf
Turbulenz
Feb 19, 2010 05:09 PM
c_keeton600f4
Dec 28, 2009 02:43 PM
G3NESYS
Mar 12, 2008 12:25 PM
sc929
Feb 25, 2008 08:15 AM
usndocjaysin
Sep 21, 2007 10:18 AM
