Need help with battery issues?
Hi all, currently having problems with the rr3s battery. Went for a long run over ten hours riding with a pillon a couple of weeks back, couple of days later awoke to a dead battery. Put the battery on charge till full then placed back on bike couple of days later awoke to a dead battery again( lights all working but not enought juice to start) anyways, went away bought a new battery and again day 2 days latter flat. mechanic has tested the regulator and assured me everything is fine putting charge to battery as normal. Can anyone tell me what the hell is going on? mechanic suggested intermitant problem maybe when ridden hard regulator could be getting too hot? any advice would be great
If the r/r is just starting to fail, yes, it will stumble as it gets hot and then cools.
Look for heat-sign on the connector or r/r, itself.
Here's the diagnostics...Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
Use your eyeballs, first and then try the link, good luck, Ern
If you got no leakage and it is charging at idle with a rise in voltage peaking at around 5K rpms then I'd check for loose or dirty connectors from alternator to R/R.
Thanks . soon as i get chance gonna give it a real good checkover.hopefully coming weekend. pulled the fuse on the headlight and tip toeing around in meantime. Bikes been faultless until this hic-up . thanks again . ill post up when i find the problem
