Need help with battery issues?
Old Apr 14, 2012 | 04:23 PM
954owner's Avatar
Unhappy Need help with battery issues?
Hi all, currently having problems with the rr3s battery. Went for a long run over ten hours riding with a pillon a couple of weeks back, couple of days later awoke to a dead battery. Put the battery on charge till full then placed back on bike couple of days later awoke to a dead battery again( lights all working but not enought juice to start) anyways, went away bought a new battery and again day 2 days latter flat. mechanic has tested the regulator and assured me everything is fine putting charge to battery as normal. Can anyone tell me what the hell is going on? mechanic suggested intermitant problem maybe when ridden hard regulator could be getting too hot? any advice would be great
Old Apr 14, 2012 | 05:34 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Regulator either works or it doesn't. If you're getting proper charging you might want to hook an ammeter in line with the ignition off and see if you've got current leakage.
Old Apr 14, 2012 | 09:04 PM
MadHattr059's Avatar
If the r/r is just starting to fail, yes, it will stumble as it gets hot and then cools.
Look for heat-sign on the connector or r/r, itself.
Here's the diagnostics...Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
Use your eyeballs, first and then try the link, good luck, Ern
Old Apr 15, 2012 | 02:35 AM
954owner's Avatar
cheers guys the mechanic checked for leakage and said it was minimal from the immobiliser. Thanks for the link mad hatter gonna check for signs of heat damage on connecters and r/r etc
Old Apr 15, 2012 | 07:41 AM
moosestang's Avatar
Something is draining your battery. If it were an intermittent problem with the R/R, then it would not start after stopping for gas or when leaving work, etc.
Old Apr 15, 2012 | 08:46 AM
Ya, that has been my experience. Last time it fried my alternator. I've seen a battery lose a cell when it gets warm but never heard of the R/R going from working cold to not working warm back to working cold. Not saying it can't happen but it's a solid state type of device.
If you got no leakage and it is charging at idle with a rise in voltage peaking at around 5K rpms then I'd check for loose or dirty connectors from alternator to R/R.
Old Apr 16, 2012 | 04:15 PM
954owner's Avatar
Thanks . soon as i get chance gonna give it a real good checkover.hopefully coming weekend. pulled the fuse on the headlight and tip toeing around in meantime. Bikes been faultless until this hic-up . thanks again . ill post up when i find the problem
willie72
Mar 16, 2013 08:51 AM
Tactician
Oct 11, 2011 09:15 AM
Megz600
Mar 17, 2011 04:44 PM
NYKnick1015
Apr 21, 2010 12:57 AM
Chuck Norris
Nov 10, 2006 12:28 AM
