battery issues
Old Mar 12, 2013 | 04:28 PM
willie72's Avatar
Default battery issues
hi i have 900rr i buy new battery and start rigth up and sudenlly few days agoi ride it for 2 hrs and stop so i tey turnit on and nothing i charge the battery and today start up two times and died and i try to turn in again ans wont start,,, any sugestions??? u guys think is a battery isues or whatelse can be? thanks
Old Mar 12, 2013 | 05:53 PM
MadHattr059's Avatar
If you know the battery is good, chances are you need to scope out your
regulator/rectifier (r/r). One of it's jobs is battery charging.
Examine the connector and the r/r, itself. Any sign of excess heat?
Melted/bubbly wires/plastic connectors? Burnt looking pins?
Heres some good info on the issue...
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
https://cbrforum.com/forum/f2-tech-9...-solved-27739/
Technical Resources - Resources for Electrical Systems on Motorcycles and ATVs - ElectroSport
Good luck, Ern
Old Mar 16, 2013 | 08:51 AM
Vinman911's Avatar
Member & ROTM AUG 2013
hook a volt meter to battery and see whats its charging at idle then rev it up to 3K and see what meter says. I bet the RR is craping out. Also make sure sure you dont have the factory RR on there( they have issues) up grade to a new style one. I wouldn't ride until you check them out. The RR can take out your stator and cost you more $$
Vinman
954owner
Apr 16, 2012 04:15 PM
Tactician
Oct 11, 2011 09:15 AM
Megz600
Mar 17, 2011 04:44 PM
NYKnick1015
Apr 21, 2010 12:57 AM
Chuck Norris
Nov 10, 2006 12:28 AM
