my 954 hard to start when its hot
Old Sep 26, 2017 | 10:06 AM
CaBaRet's Avatar
Sounds like your not getting enough amperage to the starter motor from your battery, what are the details of your battery
Old Sep 26, 2017 | 10:11 AM
Amir Koren's Avatar
ytz10s yousa
Old Sep 26, 2017 | 10:19 AM
CaBaRet's Avatar
Certainly the right battery, how are your connections (+ and - ) from the battery through the solenoid to the starter motor and back to the battery, though it starts doesn't mean your battery is ok
Old Sep 26, 2017 | 10:26 AM
Amir Koren's Avatar
this is something I need to chack
I thogth about thise cable but didnt find the time to get to there
Old Sep 26, 2017 | 10:31 AM
CaBaRet's Avatar
Yes , if it wont start off the battery alone , but then starts through the booster, its because the booster is giving an increase in amperage, could be down to the battery ,but checking the cables and connectors will help
Old Sep 26, 2017 | 04:11 PM
Gambeno82's Avatar
So update took the bike out for a spin... and i did not have a problem cranking it back up...so I am guessing that it was that connection that was loose.
CabaRet make sure you check your connections because I was having the same issue even pulled off my PC3 because I thought that was it ... and it was not... I might put it back on.
I also did a amp test and pulled the starter off to check it every thing checked out good..
One thing you can do if you think its the battery is to bypass the starter relay.
Old Sep 27, 2017 | 01:14 AM
CaBaRet's Avatar
Wasn't my post
estate4life
May 17, 2012 08:09 AM
Windsock209
Jul 22, 2010 07:49 PM
pitbull#1
Nov 13, 2008 09:02 PM
boredandstroked
Aug 24, 2008 01:32 PM
JdubsVTXXX
Jun 26, 2007 11:27 PM
