my 954 hard to start when its hot
my bike start easly when its cold, but after riding its very hard to start it again.
if i wait 10-15 min its start again just lkike normal. the charging and the battery is chacked and its OK. what can be the problem? |
Hi , could be a number of things,from ECT , Rec/Reg , Valve clearances ,Starter Motor to Vacuum Pipes, have you got a Power Commander installed?
Originally Posted by CaBaRet
(Post 1307767)
Does your Rec/Reg get really hot
dont know but electrition chack the charging system ant its OK
when I conect a boster its start better.
Is your battery new, and does it start with the booster when still hot
Yea i was having that same problem, acually got stranded a few times. I did an amp drain test on bike and every thing checked out .. I did find a loose connection in the battery area, so check there and make sure everything is well connected.. I havent rode yet to see if that fixed the problem .. I will keep the update.
Originally Posted by Gambeno82
(Post 1307794)
wait to your update Amir |
(Post 1307775)
