my 954 hard to start when its hot
Old Sep 24, 2017 | 11:15 PM
Amir Koren's Avatar
Unhappy my 954 hard to start when its hot
my bike start easly when its cold, but after riding its very hard to start it again.
if i wait 10-15 min its start again just lkike normal.
the charging and the battery is chacked and its OK.
what can be the problem?
Old Sep 25, 2017 | 03:36 AM
CaBaRet's Avatar
Hi , could be a number of things,from ECT , Rec/Reg , Valve clearances ,Starter Motor to Vacuum Pipes, have you got a Power Commander installed?
Old Sep 25, 2017 | 03:49 AM
Amir Koren's Avatar
No power commander installed
Old Sep 25, 2017 | 04:01 AM
CaBaRet's Avatar
Does your Rec/Reg get really hot
Old Sep 25, 2017 | 06:12 AM
Amir Koren's Avatar
dont know but electrition chack the charging system ant its OK
Old Sep 25, 2017 | 06:13 AM
Amir Koren's Avatar
when I conect a boster its start better.
Old Sep 25, 2017 | 06:32 AM
CaBaRet's Avatar
Is your battery new, and does it start with the booster when still hot
Old Sep 25, 2017 | 02:42 PM
Gambeno82's Avatar
Yea i was having that same problem, acually got stranded a few times. I did an amp drain test on bike and every thing checked out .. I did find a loose connection in the battery area, so check there and make sure everything is well connected.. I havent rode yet to see if that fixed the problem .. I will keep the update.
Old Sep 26, 2017 | 06:05 AM
Amir Koren's Avatar
Thanks
wait to your update
Amir
Old Sep 26, 2017 | 08:12 AM
Amir Koren's Avatar
the battery is Ok and with the boster its starts even when irs hot
