more power
Old Jul 1, 2009 | 11:49 PM
timtoo's Avatar
Default more power
i need some advice ,which delivers more hp either pc3 or msd ?
Old Jul 4, 2009 | 02:03 PM
Conrice's Avatar
depends on the map. a pc3 could make you lose power, or gain power, it all depends on the map that you choose
Old Jul 5, 2009 | 11:00 AM
timtoo's Avatar
Talking thanks but want more details
thank u Conrice,but as i understand there are more than a map so if u pls could be much specific it would help a lot.note .mine is 03 954 10k with K&N air filter,short Termignioni slip on,carbon fiber framesliders ,carbon fiber endbar&levers,smoked screen .smoked tail lite with turning signals ,carbon fiber turning signals .
Old Jul 5, 2009 | 12:49 PM
Todd84's Avatar
LOL your k&n filter is making less HP than your stock filter so why worry about the pcIII or msd? I would go PCIII it is more common and you can find them cheap. It won't make that much power just smoothes everything out and allows more power for the mods you do
Old Jul 25, 2009 | 05:48 AM
kiai's Avatar
the K&N filter will actually reduce your HP as opposed to the stock filter if you want to get some power off it do the flap mod and get a power commander and spend some dyno time tuning it also you won't get a big gain from a slip-on only like 1-2HP go with a full system and with proper tuning your out for 8-12HP of bang.
Old Jul 25, 2009 | 10:13 AM
dbehrend416's Avatar
1) Cams
2) Stock air filter (new)
3) Remove flap (airbox, and seal hole)
4) Block p.a.i.r. valves (you have to do this to use dyno)
5) Full system (depends on the way the system is configurted to make most power)
6) Power commander with shop that knows how to use the "tuning link" 13.2 - 1 air to fuel ratio.
or just buy all my HRC stuff and make a ton of power....
David
Old Jul 26, 2009 | 08:26 AM
kiai's Avatar
(y) dbehrend416 but add to that a bmc air filter and +4 ignition advance and -1 +3 gearing for a pure monster
coolbluedab
Feb 7, 2014 07:13 PM
romanboy
Jan 19, 2013 12:53 AM
__Z__
Jul 14, 2010 10:00 AM
Karmakazi
Sep 29, 2009 09:58 AM
Certified Ryder
Nov 12, 2007 10:13 PM
