L.e.d turn signals wont flash
HI, i was wondering if anyone can give me any pointers on these new turn signals that i've installed they just wont flash just stay lit up, but when i touch the + wire with - wire for a split second and seperate them they start flashing and by turning the ignition key off and then back on comes the same problem(wont flash) and also when i put on the test light to +wire on turn signal and test light hooked up with - side of battery they start flashing. am little confused service manuall does not help. plz advise and thanx in advance.
If it's a 954 you can't just change the relay. It's integrated into the instrument cluster. You have to splice the new relay into the wiring harness. The blinkers won't flash at all anyways so that's the first problem. Front blinkers? Back blinkers? LED or incandescent bulbs?
Hey man,
here is another posting from not too long ago
https://cbrforum.com/forum/cbr-954rr-21/leds-wont-blink-90867/
Lowridese
05-01-2010 01:12 AM
Gville George
02-13-2008 02:36 PM
