Turn signals stay on, don't flash unless under load
My buddy just got a '05 600rr and the turn signals will not blink unless you slowly let the clutch out while in gear. The previous owner said it's to lower the voltage or something? If you don't do that, they just come on and stay solid. The fronts are aftermarket LED's and the rear are some trailer brake lights, not LED. I'm not very electrically knowledgeable...anyone have an idea what the problem is? We're going to tear into it this afternoon.
There are aftermarket relays designed to be used with LED turn signals that will fix the problem. The other solution is to install an inline resistor somewhere close to the front LEDs so the total resistance is increased back to what it was when stock. I don't know the actual ohm value to get. My aftermarket Rizoma Zero 11 LEDs included the resistors.
Edit: Here's an example of the type of LED flasher relay I was talking about. Universal Turn Signal Flasher Relay I personally don't know anyone who has this.
Edit #2: Here's another flasher relay that claim to work with or without LEDs at the same flash rate: Electronic LED Flashers The motorcycle ones are near the bottom of the page. One advantage to using these over inline resistors is less heat buildup.
Gville George
Feb 13, 2008 02:36 PM
