Load resistors for LED turn signals
Old Mar 8, 2011 | 03:30 PM
schnezy's Avatar
Default Load resistors for LED turn signals
I bought my 01 F4i without any front turn signals. I've been looking at LED flush mounts and I know if you switch to an LED signal you need to use a resistor to bring down the power. Question is, how do I now which level Ohm and watts to buy for the resistor?
Example of possible turn signal purchase
http://cgi.ebay.com/ebaymotors/honda...Q5fAccessories
Old Mar 8, 2011 | 03:51 PM
backyardmechanic's Avatar
You dont need any resistors to switch from stock blinkers to LED ones
Old Mar 8, 2011 | 04:13 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
True, you don't "need" resistors when switching to LEDs. However, if you want the signals to flash at a normal rate you either need resistors or, what I recently did, replace the stock signal relay with an electronic LED flasher relay. With this in the circuit you can have up to 4 LED signals and the flash rate is still at the normal speed.
Here's where I bought mine. Scroll down to the bottom of the page for the motorcycle applications. The LF1-S-FLAT model plugged right into my OEM wire harness connector.
LED Flasher Relay
Old Mar 8, 2011 | 05:15 PM
Aken's Avatar
July 2008 ROTM
The LED flasher relay is a much better way to go. Most of them will allow you to have a combination of bulb and LED signals, and you don't have to monkey with wiring in resistors (which can be harder than it sounds).
Here's another source of relay: http://www.customled.com/products/fl...sher_relay.htm They even have a fancy, more expensive one that allows you to choose from 10 different fancy flash patterns.
Old Mar 8, 2011 | 06:43 PM
nowensby's Avatar
As others said... Go with the relay! 1 relay is way better than adding/removing resistors per light.
Old Mar 8, 2011 | 07:03 PM
schnezy's Avatar
Thanks RoadiJeff and Aken for the info
@RoadiJeff - I just purchased that flasher relay since I am buying LEDs for the front and rear signals, so I should be set now.
Old Mar 8, 2011 | 07:18 PM
gotcbr's Avatar
You might want to look at this HOW TO thread... https://cbrforum.com/forum/how-mechanical-40/convert-2-wire-signals-3-wire-inputs-84998/
Old Mar 8, 2011 | 08:04 PM
schnezy's Avatar
Thumbs up
Thanks dude
edit: I can just leave the wire hanging and not even worry about having it be a running light at all right?
Old Mar 9, 2011 | 04:29 PM
gotcbr's Avatar
Originally Posted by schnezy
Thanks dude
Correct.
Old Mar 9, 2011 | 05:30 PM
John Cu's Avatar
I have front (air ducts) and rear (pegs) LED turn signals and flushmounts with regular bulbs. One day i tried to install a LED flasher relay and the flash rate didn't change...
aight
May 1, 2011 12:01 PM
Smittypig24
Feb 18, 2011 10:19 PM
Lowridese
May 1, 2010 01:12 AM
bwyellowjacket
Aug 27, 2008 06:59 PM
mwsBlake
Jun 26, 2008 11:01 PM
