engine ice
Old Apr 3, 2010 | 07:58 PM
irish mike's Avatar
Angry engine ice
just replaced my coolant with engine ice and i see no differencewhat is the normal operating temp on a 954 the manual doesnt tell me-im running about 180 ish when moving and about 210 stop and go -seems aful high but i checked everything and all seems to be in order thanks mike....
Old Apr 3, 2010 | 08:33 PM
backdoc's Avatar
Your temp's seem about the same as my 954. I changed my coolant with Honda coolant last fall and my bike runs at 177-182 when moving and gets up to around 205-215 when sitting.
Old Apr 3, 2010 | 08:47 PM
kilgoretrout's Avatar
Administrator - Retired
Yep, 210 is normal when sitting in traffic. I would start to be concerned if the temp goes up to 225/230 or your fan doesn't kick on at 220.
It's good you changed the coolant, though, if it needed it.
Old Apr 3, 2010 | 08:59 PM
irish mike's Avatar
Default engine ice
yeah im glad to hear im in the right heat range but i hear every =body giving great reviews about this stuff i expected better results -i flushed the system untill water came out clear before adding new coolant...thanks mike[since the normal operating temp is 180 my bike should run at about 160 if not less since they claim that this stuff drops operating temp by up to 50 degrees]
Old Apr 3, 2010 | 09:38 PM
Kuroshio's Avatar
Been reading the F4i Owner's Manual (prepping for F4i ownership). You can download it from http://www.stephygee.com. Overheat temp is 251F / 122C. That's when the temp on the gauges will start flashing and the MIL will light.
Old Apr 15, 2010 | 01:02 PM
zibenz's Avatar
I did the engine ice change aswell, I did not notice any change maybe 2-3 degrees cooler, was truly not worth it!
Old Apr 16, 2010 | 07:37 AM
Cobra22nd's Avatar
As far as I know, water is the best for actual cooling of the engine. the other stuff is in there to lowerer the freeze point and raise the boiling point, but it also reduces the heat transfer properties of water.
I trust no mechanic in a can. For example if you buy a can of octane booster such as 103+, if you really read the fine print, it only adds like .1 of an octane rating.
lanceam24
F2 Tech
Feb 21, 2011 11:45 AM
knifemaker87
F2 Tech
Sep 17, 2010 09:21 AM
julius1
CBR Zone
Jan 4, 2010 11:32 PM
98formulaLS1
Aug 24, 2009 10:04 AM
Workwell
Jan 14, 2009 10:02 PM
