CHAIN-SPROCKET UPGRADE
Old 07-10-2007, 03:06 PM
bajaroots's Avatar
Default CHAIN-SPROCKET UPGRADE
looking to upgrade from stock chain and sprocket 43-16 to maybe 45-15 or 43-15 any suggestions looking to get better take off midrange and top end
Old 07-10-2007, 04:17 PM
bobjoezx's Avatar
Default RE: CHAIN-SPROCKET UPGRADE
-1 +2 is a good upgrade but will make the 954 real snappy.. how much expierence do you have? -1 is a nice overall but all depends on your goals and your expierence.. i did -1 +2 when i was new to the bike but after i got used to it i like stock gearing so try a few ratios out and figure out what is best for YOUR riding style
Old 07-10-2007, 04:21 PM
I went -1 on my 900RR and it was a great choice. I only went +2 on my GSX-R ( a little less than -1) because does it really need any help? Start with -1........that'll give you a good noticable difference. You will enjoy it.
Old 07-11-2007, 03:24 PM
txsmainevent's Avatar
ok u say u want a better take off, midrange, and top end? ur not gonna get all three by changing your sprockets. ur either gonna get quicker take off/midrange or midrange/top end, u cant achieve all three wit sprocket changes. if u lose a tooth up frontand add to the rearur gonna lose top end, if u add a tooth up front and lose a tooth(teeth) in the rear ur gonna get higher top end.
Old 07-14-2007, 12:29 AM
yea dude pick your poision: high speed, mid range or of the line and then you will get a better answer out of these guys...
Old 08-20-2007, 12:17 AM
I went -1 + 2 and I love the launching power. but it makes the bike a little jumpieif you are not watching it. But I drag race the bike so I was looking for quick rather then top end.
Old 08-20-2007, 02:24 AM
I ride a 99 900rr. I ride in japan and the top speed limit is 80KPH. I have been reading here about the 520 conversion. I like the idea of having alittle more at start. On the main roads limit is about 40KPH, so I don't think the conversion will hurt my in city ridding. However my question is will the conversion mess up my speedo read out. Also any special tools required for this.
[IMG]local://upfiles/19626/869DF5E66E744CACBB34D0CE60A7F100.jpg[/IMG]
Old 08-26-2007, 09:49 AM
Tools NO you can take the rear off the bike I about 15 min with a few basic tools everyone has. and to change the ft. all you need is the same basic tools well you do need a torque wrench. but it is easy to do. I just changed mine tot he 520 kit and I went -1 +2 and I love it.
And Yes your speedo will be all jacked up. I am waiting on a speedo healer to come in. I seem to be off about 1 to1 1/2 mph per 10 mph and that is way toomuch to think about when you see johnnie law at higher speeds.
Old 08-29-2007, 01:21 AM
Ok thanks, I will look into the speedo healer.
WBBulldogs
07-10-2009 04:36 PM
GARMIN1000F
01-22-2008 04:06 AM
sixtwoishere
11-19-2007 06:30 AM
hurricane1000
01-17-2007 01:45 PM
Quick Reply: CHAIN-SPROCKET UPGRADE
