CHAIN-SPROCKET UPGRADE
RE: CHAIN-SPROCKET UPGRADE
-1 +2 is a good upgrade but will make the 954 real snappy.. how much expierence do you have? -1 is a nice overall but all depends on your goals and your expierence.. i did -1 +2 when i was new to the bike but after i got used to it i like stock gearing so try a few ratios out and figure out what is best for YOUR riding style
ok u say u want a better take off, midrange, and top end? ur not gonna get all three by changing your sprockets. ur either gonna get quicker take off/midrange or midrange/top end, u cant achieve all three wit sprocket changes. if u lose a tooth up frontand add to the rearur gonna lose top end, if u add a tooth up front and lose a tooth(teeth) in the rear ur gonna get higher top end.
I ride a 99 900rr. I ride in japan and the top speed limit is 80KPH. I have been reading here about the 520 conversion. I like the idea of having alittle more at start. On the main roads limit is about 40KPH, so I don't think the conversion will hurt my in city ridding. However my question is will the conversion mess up my speedo read out. Also any special tools required for this.
[IMG]local://upfiles/19626/869DF5E66E744CACBB34D0CE60A7F100.jpg[/IMG]
Tools NO you can take the rear off the bike I about 15 min with a few basic tools everyone has. and to change the ft. all you need is the same basic tools well you do need a torque wrench. but it is easy to do. I just changed mine tot he 520 kit and I went -1 +2 and I love it.
And Yes your speedo will be all jacked up. I am waiting on a speedo healer to come in. I seem to be off about 1 to1 1/2 mph per 10 mph and that is way toomuch to think about when you see johnnie law at higher speeds.
bowtieboy42
F2 Tech
07-10-2012 03:53 PM
