CBR954 Injector seems stuck
Old May 2, 2024 | 01:16 PM
turbofied's Avatar
Unhappy CBR954 Injector seems stuck
Hello everyone,
Just bought this as a non runner. Been sitting a few years. Replaced the fuel pump with a cheap aftermarket unit from ebay. Started the bike and all seemed ok although I did not ride it.. I installed a new battery the next day and the motor seemed to hyperlock. Engine would not turn over. Could an injector be stuck? Fuel dripping out of the exhaust. Is there a way to check the injectors? Is there an aftermarket injector or is it best to go with stock?
Thanks in advance for your time.
Old May 2, 2024 | 07:18 PM
rockpool's Avatar
Either an injector is stuck or there's a short keeping it open. The former is most likely. You can check them using an injector cleaner adaptor, a can of cleaner and not supplying power - if cleaner flows through without power, the injector is stuck open, it it does, the injector works (and you cleaned it!)
Old May 2, 2024 | 09:50 PM
dannoxyz's Avatar
If injector’s dripping when everything’s off, might be clogged and stuck open. Remove all injectors and test for leaks, then measure flow-rate.
Old May 3, 2024 | 11:28 AM
turbofied's Avatar
Thank you for the advice.
Old May 3, 2024 | 11:29 AM
turbofied's Avatar
Where would you purchase a injector cleaner adapter? Is it 1 size fits all?
Thanks again
Old May 3, 2024 | 11:30 AM
turbofied's Avatar
Thanks. That was informative.
Old May 3, 2024 | 01:21 PM
dannoxyz's Avatar
None of injector cleaners work properly because they don't back-flush injectors in reverse. I think only one I've seen that's proper flow-direction is Toyota's kit.
2003_CBR600_F4i
Feb 11, 2022 08:34 AM
unnecessary
Apr 29, 2020 04:11 PM
joeymats
May 30, 2019 09:12 PM
colorado03cbrf4i
Jan 31, 2007 02:16 PM
