which injectors?
Old Jan 30, 2007 | 03:43 PM
colorado03cbrf4i's Avatar
Default which injectors?
what injectors would swap in to a f4i? i need a fuel upgrade for my boost set up......would any larger cc bikes work...or even ones for a car?
my buddy that builds turbo kits for busa's is building me one for my bike......and the only problem im running in to is a fuel system...im going to be using a fmu to boost the pressure...but i need some injectors that will flow enough fuel to support atleast 150 whp......
also...does any one know if a 255 fuel pump for a mustang or even a honda will work with modifactions?
thanks
Old Jan 31, 2007 | 12:30 PM
Default RE: which injectors?
alright...no comments...i guess i will just have to try them out..
Old Jan 31, 2007 | 12:39 PM
Candymanmo06F4I's Avatar
Sorry about that dont have a clue
post back and state results
Old Jan 31, 2007 | 01:38 PM
D2VW14_20's Avatar
Check out what size injectors you need. I know stock Honda S2000 injectors are the same size as aftermarket upgrades for busas, so maybe you will be able to find something like that. As far as a pump, check out ebay. But mosre likely then not, some type of car will have the size injectors you need to upgrade too, and you will g et a hell of a deal on them instead of buying aftermarket F4i injectors.
Old Jan 31, 2007 | 02:16 PM
speedra500's Avatar
are the f4i injectors saturated or peak & hold? low impedance or high impedance?
LRS122
Jun 16, 2022 10:04 PM
anthonygilbert
Apr 2, 2009 08:15 AM
jeh2324
Mar 25, 2009 02:16 PM
turbof4i
Sep 10, 2008 08:06 PM
