Battery draining while sitting
Old Dec 20, 2007 | 03:40 PM
jutsin's Avatar
Default RE: Battery draining while sitting
prolly just the battery... as far as u saying there is voltage going from - to + with the bike off that is completely normal and will always happen. If you are concerned about a parasitic draw you will have to pull the positive lead on ur multimeter and put it in the mA spot... set ur multimeter for the smallest amp scale possible, then you disconnect your negative terminal from your battery, hook the negative side of the multimeter up to the battery post, and the positive to the negative battery terminal. In a car, typically anything more than 40 milliamps is a problem..i would assume it would be less than that in a bike. Make sure you swap the positive lead on ur multimeter back from the mA plug when you're done or you will fry the fuse inside if you try to do anything else.
Old Dec 20, 2007 | 05:47 PM
demonchild's Avatar
Hold on?
4 year old battery? Sitting for a couple of weeks between starts? Any you are worried about this?
Get a new battery. You are not draining anywhere. The atmosphere is probably draining you faster than the electrical system.
Old Dec 20, 2007 | 06:01 PM
Mikes03954RR's Avatar
Get a new battery. If you lose charge after a couple of rides or a week or two of sitting, you have a different problem. You would then need an ohmmeter to check the voltage regulator/rectifier. This is what charges the battery while the bike is running. I had this problem on my old bike.
Old Dec 20, 2007 | 06:54 PM
doogstar's Avatar
I with Mike. My bike was doing the same thing a few months back, and I bought a Battery Tender from a local shop. When I told them what it was, They said to just order a new battery. Just when I was going to, it was acting right again. I think it just needed to be fully charged. I dont keep it on the tender all the time either. Worth a try.
Old Dec 20, 2007 | 07:43 PM
outsider8's Avatar
ORIGINAL: kinome79
Sorry, this is long, but then again, electrical problems always are.
I have a 2002 CBR 954 RR, and lately if I leave the bike sit for more than a couple of weeks, the battery will be almost dead. The battery is about 4 years old, so I figured it was just the battery. If I run the bike for about 20 mins, the battery charges right back up, and I never have to worry that the bike won't start again unless I let the bike sit for another 2-3 weeks. I was going to buy a new battery but a new one is so expensive, and since I'm selling the bike anyway, figured I'd just let the new owner know, and take it out of the price of the bike. Plus Autozone tested it, said it held a charge, even under load.
Now, I've been working on an electrical charging problem with my other bike, a '92 VFR 750 F, and one thing I checked for was a leak in the electrical system that can drain the bike while sitting. I'm not having that problem with it, just wanted to check though. Basically, I would think if there is any continuity between + and - battery lead wires while the bike is off, current will leak from the + to the - terminal of the battery, and the battery will slowly drain while the bike is off. I checked the terminals on the VFR, and there is no continuity between them, so no current will flow. Thats a good thing. Now just for reference, the electrical system on the VFR is pretty simple, no computer, no digital clocks, nothing that needs power while the bike is off.
I thought it weird that the battery on the CBR would hold a charge just fine, but dies a few weeks later if not ridden, so I decided to check for a leak in the electrical system of the CBR as well. First I checked the battery voltage, 12.39V. I then disconnected just the negative battery lead. Now someone told me if you hook an indicator light from the negative terminal of the battery to the disconnected negative battery lead and it lights up, you have a leak. I don't have a light, so just checked for a voltage difference. Uh Oh, there was an 11.45V difference between the negative terminal and the disconnected negative terminal lead. Voltage is making it from the positive terminal through the electrical system to the negative terminal somehow. Not good. So I disconnected the battery completely. I checked for a voltage difference between the negative and positive lead wires, there was about a .400V difference that slowly counted down as I watched it (.400, .399, .398, .397, .396, etc) and would keep counting down. I have a really good Multimeter. I then checked resistance between the two leads, it showed about 3.53 megaohms, and counted up while I watched it. Apparently, with the changing voltage and resistance, I'd guess I am dealing with a capacitor or something. While I'm testing resistance(which supplies voltage through my multimeter), the voltage difference and resistance counts up as the capacitor charges. When I'm not testing resistance, the voltage and resistance counts down (capacitor charging and discharging). Now, I'm not sure, but if the bike is off, shouldn't there be no continuity between the positive and negative terminal? Or is the electrical systems on these newer bikes more computerized and complex, and therefore there is a connection between the positive and negative terminal even when the bike is off to like run the clock and stuff. Has anyone ever checked this on their bike? Is my battery old and just needs replaced? Any help would be appreciated.
do a simple draw test-you will need a good multimeter-test system draw-remove neg cable from battery-place one end of meter to removed end,then place the other meter
end on the neg post(on battery)-set the meter to amps-what does it read??(DO NOT ATTEMPT TO START-YOU WILL F**K UP THE METER!!)
this is where i would start!!-it sounds like you need a new battery!!
Old Dec 20, 2007 | 09:14 PM
bobjoezx's Avatar
just go get a new battery - not from dealership and pick urself up a battery tender.. i dont know where you are located but if you useing for long periods of time. .put on the battery tender the battery will last u years..
Old Dec 20, 2007 | 10:18 PM
demonchild's Avatar
11 year battery?
Who cares? It is like these people that boast about running some oil in thier engine for 100,000 miles. If you are that cheap for maintance send the machine to me. Ill maintain it correctly.
Old Dec 20, 2007 | 11:49 PM
bobjoezx's Avatar
ORIGINAL: demonchild
11 year battery?
HMM i would have to disagree.. if you are smart enough to make a battery last 11 years.. more power to ya.. that is really not "maintence" if the battery has enough power to run the machine.. great.. but yes on the other hand oil changes. spark plugs.. washing it and those sorts of things if you cant do that on any type of vehicle then why buy it .. [quote]ORIGINAL: demonchild
Old Dec 21, 2007 | 09:49 AM
You have to realize that this was an extreme case. 11 years is a very long life. Batteries in motorcycles take a huge beating because of the vibration they constantly take. This guy in the article put less than 1000 miles a year on his bike. My motto is if it ain't broke, don't fix it. You still gotta do routine maintenance like bobjoe is saying.
waynecbr600rr
May 15, 2013 05:46 AM
jays-shop
Feb 27, 2013 12:07 PM
GunMedalGleam
Aug 10, 2009 01:37 PM
njdjh2o
Apr 11, 2008 07:20 PM
teetoe24
Aug 9, 2005 01:46 PM
