Bad luck!
Old Jan 28, 2013 | 06:48 PM
Dazed's Avatar
Default Bad luck!
So me and my buddy pulled off the cracked stator cover on my bike, the crack on the stator cover ran down to the left of the actual stator on the engine.
We expect it a bit more and there was a crack running down the actual stator casing towards the left. I don't get how it cracked towards the left when the crack was towards the right on the actual cover... puzzled me, and pissed me off beyond believe the crack is small but we applied JB weld to it. Looks like things just got a lot worse. I'm not sure if it was leaking through the crack to begin with but we JB welded it regardless.
I don't see how the crack ran up the actual engine case on the left hand side if this crack is on cover is on the right? any insight thanks.
Old Jan 29, 2013 | 10:36 AM
Conrice's Avatar
it just happens. it's actually a fairly common place that these motors crack when people go down on that side. a guy i sold my bottom case to had the same thing happen to him.... any pics of the crack on the case?
Old Jan 29, 2013 | 10:41 AM
Dazed's Avatar
What can I do to fix this? Can it be welded? the JB weld doesn't seem to be holding right now because it's so cold out. Man I'm pissed off.
Would the engine need to be pulled in order to TIG weld? How much are you looking at price wise.
It looks similar to this. Only mine is deeper.
gtcole
Jul 30, 2013 10:06 PM
Dluv35
Nov 3, 2008 11:55 PM
voodoochyl
Feb 26, 2008 10:15 AM
Dj_Squatch
Feb 12, 2008 11:16 AM
JZHALES
May 13, 2007 01:44 AM
