954 to sport touring
Old Jul 13, 2012 | 03:21 PM
hontri's Avatar
New Member
Default 954 to sport touring
Hello! New guy here. First post. My 954 has served me faithfully for 10 years. I would like to convert it to sport touring duties. I would like to raise the handle bars 2-3 " which would necessitate new control cables. Might even like a little higher windshield.
Has anyone done this or know where i might source the above mentioned items? Thanks for any info!
Old Jul 13, 2012 | 04:20 PM
Hudson's Avatar
Nice idea, would be interested my self but maybe not that far up, i have heard that Helibars are just about right but being in the bloody UK we can not get them without either selling one of our children or one of our more important body parts !!!!
Old Jul 13, 2012 | 06:28 PM
letsride's Avatar
Zero Gravity makes a sport touring wind screen.I have one mounted on my bike.
Old Jul 13, 2012 | 10:39 PM
Blues48's Avatar
http://www.topyokes.com/comfort_kit_+_handlebars/184
Try these, if I had to do it, this would be high on my list.
Old Jul 14, 2012 | 10:19 AM
Conrice's Avatar
you'll definitely need new brake lines. you'll have to adjust the cables and what not to make them work - but i was able to make them work. clutch cable shouldn't be too big of an issue. all the wiring from the controls will easily work too - just use some zip-ties to keep them tucked to the bars
that top yoke is nice, but you could use your stock yoke and use a set of these and buy your own 7/8 bar
Freestyle Ingenuity Handlebars Risers CBR929RR 00-01
not sure how dirty bars work with the fairings though....
Old Jul 14, 2012 | 10:22 AM
Conrice's Avatar
man, you know what i'd like to be able to get my hands on? a windscreen that's the size of the isle of man bikes.... those things look awesome
you think they're all custom made?
Old Jul 14, 2012 | 02:24 PM
letsride's Avatar
I'd say they are since I have never seen them anywhere else.
Old Jul 14, 2012 | 07:11 PM
MadHattr059's Avatar
I'm looking to do a similar conversion to my F3. I'm going to add the Throttlemeister bar-end,
cruise control to mine, as well. I've been doing the research and looking for the bargains for the last 6 months.
The best (and least expensive) solution I've found is the APEX 3" riser clip-ons.
They are a hollow bar and adjust forward/back and up/down. They run $220 for any diameter fork tube.
You can find them here...
Apex Clip-on Sets - Apex Manufacturing
Another (less expensive) solution is the DanMoto 3d clip-ons. Pretty much the same design and
range of motion. BUT it uses a solid bar, made of soft aluminum. This is more a track-style set,
engineered to bend in a crash and prevent a tumble. If you are wanting bar-end weights or the
afore-mentioned cruise control, you'll have to trim and drill them. You can find them here...
Adjustable Billet Clip On's : Danmoto
With the range of motion either of these offer, I would mount them first and see if your cables
will work without replacement and still hit the sweet spot.
If not, THEN consider longer control cables and/or hoses.
In case you're interested, here's a link to the Throttlemeisters. There are a lot cheaper options,
but these are pretty and give that stock look that I favor.
Throttlemeister - Home
Hope this helps, Ern
Old Jul 15, 2012 | 09:48 AM
Conrice's Avatar
those adjustable clipons are probably the way to go. but you'll still need brake lines if you want to be able to adjust them. just call galfer and say i need 954/929 lines +4 inches or whatever you decide and you're done
RydnaCBR
Dec 30, 2013 10:32 AM
Dragondima
Jan 22, 2013 02:37 PM
hawkwind
May 2, 2012 05:10 PM
Honda Nut
Aug 27, 2009 10:59 AM
redcbrman
Oct 20, 2007 08:55 AM
