Trying to speed up
Old Feb 14, 2013 | 04:36 PM
john87's Avatar
I have a pc3 for sale 125
Old Feb 15, 2013 | 10:03 AM
maverick0716's Avatar
Originally Posted by Conrice
interesting story in SSB, if you try to change the rear sprockets to make the bike "quicker", you'll dyno less hp....
same dyno, same bike, same day
stock gearing dyno'd highest (150.1hp)
-1/+2 lost a few hp(-2hp)
-1/+5 lost the most hp (-4.5hp)
it makes sense if you think about it. when you dyno a bike - you don't dyno it in first gear.... you dyno it is your highest gear. and that's because it gives you the most hp - and your motor is doing the most work. if your motor can do less work (like with different sprockets) you'll dyno less hp. interesting story
I'd be interested to see the torque numbers on those dyno pulls....I bet they're a bit higher than stock.
Old Feb 15, 2013 | 06:25 PM
Conrice's Avatar
under the same logic, they'd be lower too. thats why you do your power runs in an upper gear. the engine is then under the most load, so that's when its doing the most work - so torque would/should follow suit
but they didnt have those numbers in that article, just the hp numbers
edit- but lets be clear, this is JUST for numbers on a dyno. that's not saying that your bike makes more hp with a smaller rear sprocket. it just registers higher readings. if torque registered higher in lower gears (motors under less load), you'd see diesels doing their runs in a low gear, but they don't - they do them all in high gears. and while they do care about hp, the thing they tend to brag about is how much damn torque their trucks make.
Old Feb 15, 2013 | 08:59 PM
I always thought they dynoed vehicles in the gear that is closest to 1:1 ratio (usually 4th gear for a manual). Not sure what gear that would be for bikes.
Old Feb 17, 2013 | 08:11 PM
fiddy_nutz's Avatar
I also want to "speed up" lol do you still have that PC3 John?
hondaboy1998
Mar 8, 2010 05:46 PM
Az1kF
The Hurricane Saloon
51
Dec 12, 2009 03:11 AM
davydave
Aug 30, 2009 04:46 PM
000CBR000
Aug 14, 2008 09:38 PM
VP
Nov 10, 2006 04:08 AM
