Strange noise from top engine
Old May 23, 2009 | 12:51 PM
baddest's Avatar
Unhappy Strange noise from top engine
I have a cbr 929 and i noticed yesterday a strange clicking noise while i was driving at high speed. I thought it was normal or maybe due to heat because the bike is noisy in general but i was not. This noise starts as soon as i hit 3500rpm and i have no idea why. I tried it again the next day and the sound is starts when i hit 3500rpm. might it be the valve, did my engine oil degrade or am i runing low on engine oil?? it sounds more like the valve because i put mobile 1 engine oil and i have only covered 5000k since the last oil change... am really not sure what the problem is but i really need help on this one because
Old May 23, 2009 | 04:48 PM
bwayers's Avatar
it can be your valves, possibly due to oil or maybe clearance issues; could be cam chain tensioner
Old May 24, 2009 | 06:25 AM
baddest's Avatar
Thumbs up
I appreciate it bwayers i will take it to honda and get it checked out... do you know if it will affect anything else if i do not get it checked out ASAP???
Old May 24, 2009 | 10:12 AM
seldon929rr's Avatar
If it is a ticking coming from the front right side of the tank it is the cam chain tensioner it's almost the same sound as a dead spot in the chain but opposite end, lol.
Old May 26, 2009 | 07:57 AM
packdog's Avatar
sounds like the CCTL. do a search on "CCT tick" or "CCTL tick" you'll see a lot of people have the same issue. If it is the CCTL it's nothing to worry about at all, just annoying. there are ways of fixing your stock CCTL rather than buying a new part or going aftermarket, let me know if your interested and i can point you in the right direction.
Old May 29, 2009 | 10:16 AM
steves11's Avatar
Most likely CCT. There's a fix if you search on here to use a longer bolt inside the tensioner housing.
Warhorse
Mar 18, 2014 05:15 PM
Parnavaz
Jan 1, 2012 10:45 PM
cbrpsycho
Nov 26, 2009 03:16 PM
rg_series
Jul 10, 2006 05:22 PM
rg_series
Jul 9, 2006 11:04 PM
