start?
there should be a safety switch on the kick stand. If that isn't bad then it's your neutral safety switch. Neither should be too expensive. but neither are needed for operation. If it isn't a much then just kick it in neutral to start it.
When you say "it starts in neutral with the stand down just not in gear stand up or stand down clutch in or out", it's telling me the neutral switch is probably working right. Sounds like the clutch switch or the stand switch. This should be an easy one, you just need an ohm meter or a continuity test light.
I just cut the kill switch on the kickstand and it still does it. I think it's the safety neutral switch No big deal I'll just put it in neutral when it doesn't start in gear. Thanks guys
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
JayBoCC2
Jun 23, 2009 10:23 PM
