start?
Old Oct 4, 2006 | 09:51 AM
seldon929rr's Avatar
Default start?
bike won't start when in gear sometimes. put it in neutral and it fires. Any help? (yes I grab the clutch and the stands up)lol.
Old Oct 4, 2006 | 01:23 PM
doggy69's Avatar
Default RE: start?
I think my bike will start with the stand down....i am guessing the neutral safety switch is no good....its what stop a car from starting unless the clutch is depressed...
Old Oct 4, 2006 | 02:46 PM
Default RE: start?
it starts in neutral with the stand down just not in gear stand up or stand down clutch in or out. I don't know what happened.
Old Oct 4, 2006 | 04:37 PM
Triax's Avatar
Default RE: start?
It should have to be in neutral with the kick stand up or down. If its in gear and the kickstand down it won't start. Its a saftey thing so you don't take off with your stand down.
Old Oct 4, 2006 | 07:16 PM
Default RE: start?
the stand is up when in gear clutch is mashed injectors kick on, still won't fire.
Old Oct 4, 2006 | 07:31 PM
weeble1's Avatar
Default RE: start?
there should be a safety switch on the kick stand. If that isn't bad then it's your neutral safety switch. Neither should be too expensive. but neither are needed for operation. If it isn't a much then just kick it in neutral to start it.
Old Oct 5, 2006 | 01:05 PM
sixs929's Avatar
Default RE: start?
When you say "it starts in neutral with the stand down just not in gear stand up or stand down clutch in or out", it's telling me the neutral switch is probably working right. Sounds like the clutch switch or the stand switch. This should be an easy one, you just need an ohm meter or a continuity test light.
Old Oct 5, 2006 | 01:19 PM
Default RE: start?
I just cut the kill switch on the kickstand and it still does it. I think it's the safety neutral switch No big deal I'll just put it in neutral when it doesn't start in gear. Thanks guys
Old Oct 5, 2006 | 09:57 PM
QuinC's Avatar
Default RE: start?
have you tried in first gear? mine will start in first but not in second.
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zophill
Apr 20, 2010 07:10 AM
CTcbr929
Jul 31, 2009 12:25 PM
JayBoCC2
Jun 23, 2009 10:23 PM
