Shifting/accleration
Old Mar 20, 2006 | 05:59 AM
DerBarbarian's Avatar
Default Shifting/accleration
Hey guy's a little new to the biker scene so dont bash too hard, When i'm shifting.. is there an ideal rpm to shift at?.. i generally take it to 4 or 5.. depending on what gear i'm in.. Also if i'm on the city streets if i lay off the throttle a bit then hit it again, i get kind of a clunky sound then it goes without a hitch.. newbie questions i know.. but i just want to be on the safe side .
Old Mar 20, 2006 | 01:49 PM
speedy's Avatar
Default RE: Shifting/accleration
well ur bike doesnt come alive till after 6000 rpm thats where all your power lyes shifting around 9000 and red line hahahahaa thats where i shift infact im never under 6000 this way im ready for anything
Old Mar 20, 2006 | 04:31 PM
joe200803's Avatar
Hi mate when you get back on the power the clunnky niose is the slack in the chain been taken up so nothing to worry about but just check the chain adjustment anyway to be on the safe side.
Old Mar 20, 2006 | 07:13 PM
sixs929's Avatar
Right on, joe200803. Mine does the same thing.
As far as RPMs and shifting, I admit I'm taking a bit of time getting used to the 929's close-ratio trans. When I'm really hitting it, it's almost like the trans could have been a 4-speed, the gears are so close. I'm mostly highway, and I get the impression the close-ratio trans was designed for a winding track with lots of turns. A lot of times I skip 3rd and 5th.
Old Mar 21, 2006 | 05:24 AM
So, my chain was 10mm too tight or so they said when they checked it out.. how should i go about changing the slack of the chain?.. i'm really new to bikes so i dont know exactly what i can do and what i cant do.. Another question a little off the topic, but i've noticed when i punch it at a light on getting on the freeway i'll get a little gas odor.. not sure if its running rich or maybe its leaking a little gas out of one of the lines.. they did a test to check for leaks when i got it inspected and it came back good.. so i dunno.. tips would be appericiated.
Old Mar 21, 2006 | 07:00 AM
NINE2NINE's Avatar
Retired Mod
ORIGINAL: DerBarbarian
to loosen the chain, you first need to loosen the axle nut (on the non-chain side) and then turn the adjusters on both sides until the slack is within specs. make sure to turn the adjusters the same on both sides or the tire/wheel will not be tracking properly. i use a caliper to measure the distance to make sure that they are the same (not necessary but i'm a little overcautious.) there are markings on the plates on both sides of the swingarm for reference points.
and for the gas smell, no idea. could be a gas leak. could be an overly rich condition. could just be an exhaust smell. really cannot diagnose that without knowing which model of 929 (cali, euro, 49-state) that you have. if its the cali model, then i would assume that it is probably the useless extra garbage that was added by the factory. if it is a lean condition, then i would recommend a plug change and possibly a pc3 to ensure that you are getting the proper air/fuel ratio for your setup. and they supposedly checked for gas leaks, but i would check again to make sure. you stated that you get the smell when punching it at a light so i highly doubt it would be a fuel leak. the smell would be constant, even when sitting without running.
Old Mar 21, 2006 | 07:31 AM
I'll Take a close look tomorrow.. i certainly hope there aern't any leaks.. then again it's merely the problem of replacing a clamp... as far as the plug change, it has 9,400 on the clock, it had the 8,000 mile service done about a year ago....I'm kinda scared to dive into this haha.. i am assuming i can search for it, but can you guys maybe point me in the right direction of service requirements of the bike? like when to take it in and get the fluids changed, tune ups etc?.. just want to make sure it's getting the proper care
Measuredpath
Jun 25, 2009 03:03 PM
focus01
Apr 1, 2008 08:23 PM
riekky
Jul 15, 2007 07:03 PM
markobenin
Aug 2, 2006 12:33 AM
ddvs
May 25, 2006 09:43 PM
