Shifting
Old Mar 30, 2008 | 03:07 PM
focus01's Avatar
Default Shifting
I have a 1989 cbr 600 f that has an intermitant problem with not wanting to go to neutral and hard shifting to 1st and second during this time. It did it once last year and I just started riding it last week and it has already done this about 5 times. In order to get it to go to neutral I have to grab the shifter and manually try to find neutral which usually takes quite a bit of shifting in and out of 1st and 2nd??[:@] Anyone had this happen before?? Thanks for any help
Old Mar 30, 2008 | 05:40 PM
dwschultzy's Avatar
Default RE: Shifting
When was your last oil change?
Old Mar 30, 2008 | 05:41 PM
dwschultzy's Avatar
Old Mar 31, 2008 | 01:27 PM
focus01's Avatar
I honestly dont know I bought it last Oct and I just got the carbs cleaned so I can let it warm up so I can drain it.
Old Mar 31, 2008 | 03:39 PM
Lrn2Go's Avatar
Your bike uses a "wet" clutch... the oil lubricates all parts of the engine and transmission. If it get's all gunked up, shifting is effected (as is less noticible engine parts). That would be number one on my list of things to try first! (new motorcycle oil and filter!)
Old Mar 31, 2008 | 09:02 PM
mcwheelie08's Avatar
another issue coud be your idle adjustment sometimes when your idle is too high or too low it can be very difficult tofind nuetral and get it to shift with out clunking real hard i belive for that bike the idle should be like 25 00 to 2700 rpms give it a shot real quick if your idle is off
Old Mar 31, 2008 | 09:28 PM
FNQuickF2's Avatar
^^^^NOPE!^^^^ Your Hurricane should be idling at @1500 + - 100rpm's...
RB
Old Apr 1, 2008 | 08:19 PM
focus01's Avatar
I changed oil and it shifts better but it still does not like to go to neutral when I am at a stand still. If I rock it back and forth and keep shifting from 1st to second it will go in after a couple times of that. Another question afterI changed oil I started hearing noise come from the head area of the engine. It increases as RPMs increase.
Old Apr 1, 2008 | 08:23 PM
focus01's Avatar
I also adjusted the idle. The manual states it should be 1200 + - 100 RPM
rell123456
Aug 6, 2014 01:37 PM
Measuredpath
Jun 25, 2009 03:03 PM
riekky
Jul 15, 2007 07:03 PM
KidCr3nshaw
Oct 18, 2006 07:10 PM
mr tone
Sep 25, 2006 10:10 PM
