runs like its runing off two cyclinders smokes ,muffler smells like raw gas.help please
Old Sep 4, 2007 | 02:45 AM
jcf241's Avatar
Default runs like its runing off two cyclinders smokes ,muffler smells like raw gas.help please
i rode my bike yesterday about a hundred miles ran good all day then it started to stumble like it was runing out of gas ,so i stoped and gas was half full,so i started to ride home the whole way i couldnt keep the rpms smooth thay hept jumping and bike spuddered.i thought i was some bad gas so i draned the tank an put some new gas in and some fuel cleaned in the tank, a about a half a cup,then rode the next morning it ran a little better for about fifteen minits then started to miss and spudder,i tryed to baby it to get home it just got worse it started to sound like a four stroke dirt bike well not quite but real bad and no power,i just about got home i stoped at a light then went to take off and i seen smoke coming out of the pipe just untill i got past 3000 rpms, i pulled into my drive was and tryed to make it idle so i could look over the bike ,i gave the bike a little throtle it smoked a little, i smelled the pipe to see if it smelled like oil or coolent,,,, but it smelled like raw gas so bad it shocked the hell out of me it about knocked me out..anyways i coud realy use some help..............thanks jesse.....
Old Sep 4, 2007 | 02:52 AM
demonchild's Avatar
Default RE: runs like its runing off two cyclinders smokes ,muffler smells like raw gas.help please
Possible that an injector is sticking open. Take the injectors out but leave them connected to the wire harness. Turn the key to on so that the fuel pump primes. If any of the injectors are stuck open they will squirt fuel at this point. If this does happen, replace the injector. If it doesn't you are not out any money. Always diagnose the easy things first. Also, make sure there is spark to all cylinders and that the plugs look good.
Old Sep 4, 2007 | 04:58 PM
jcf241's Avatar
thanks, ill give that a try hopfuly thats all it is,
Old Sep 4, 2007 | 06:56 PM
jcf241's Avatar
hello, i tested the fuel injector thay were good ,plugs were a little wet in number 3and4 cyclinder so i put a new set of plugs in geting good spark but still runs like crap,,anything else you can think of ,,what about fuel regulater????any way to test that..anyone thanks for your time...jesse
Old Sep 4, 2007 | 07:57 PM
jcf241's Avatar
help....any one have any ideas on what s up....
Old Sep 4, 2007 | 10:58 PM
ReSpEcT's Avatar
Fuel Pump Regulator...I've seen it fail and drop cylinders 3 and 4.....Might wanna check that...=-)
Old Sep 5, 2007 | 01:35 AM
demonchild's Avatar
If the injector are good start to look toward the sensors. I am not totally familiar with the fuel system on the 929, however, it should have some kind of MAP sensor to tell the computer the pressure in the manifold. If that sensor fails, it will default to complete rich and make the bike run crappy.
Old Sep 5, 2007 | 01:37 AM
demonchild's Avatar
also, a fuel pressure regulator should only make the bike run rich fuel system is a return system (im not sure of it is). Try to research a way to test the MAP sensor because it is a 150 dollar sensor. Also, is you FI light on?
Old Sep 5, 2007 | 07:00 PM
jcf241's Avatar
FI light is not on,
Old Sep 7, 2007 | 02:42 AM
jcf241's Avatar
thanks for the help i fount the problem ,,a wire that goes to the power comander that runs the number one fuel injector was rubed throught from the seat rubing one the wire, it was grounding out on the seat latch making the number one fuel injector blowing extra fuel in the cyclinder easy fix some black tape runs like a champ thanks you all for the help )))00$$$$$$ spent just time good luck thanks demonchild thanks respect for your time.......jesse
halomatic
Sep 5, 2010 10:15 AM
Ken Thurman
Jul 29, 2010 01:00 AM
CrAzyHuRRicAne
Oct 21, 2008 07:07 PM
grim129
Jul 29, 2007 10:44 PM
