runing on first 2 cylinders
Old Oct 17, 2008 | 11:07 AM
CrAzyHuRRicAne's Avatar
Default runing on first 2 cylinders
Hey my bike seems like only the first two cylinders get hot when first running. Is this normal till it warms up? bad ground maybe clogged jets?
Old Oct 17, 2008 | 12:16 PM
HeresJonny's Avatar
Default RE: runing on first 2 cylinders
how can u tell
Old Oct 17, 2008 | 01:47 PM
header pipes of course
Old Oct 17, 2008 | 02:07 PM
Hurricane rider's Avatar
could be, and PROBABLY is a carb issue. check your spark and the plugs first though, they're easier than pulling the carbs off. if they work fine, your problem is likely in the carbs.
Old Oct 17, 2008 | 03:36 PM
jonld's Avatar
I would say weak coil but if its 2 inline cylinders then that would throw that out. It wouldmost likely be plugs, carbs, or valves then.
Old Oct 17, 2008 | 09:01 PM
HeresJonny's Avatar
oh ok headers, ok now that i know how to check ill check mine tomorrow if i remember.
Old Oct 17, 2008 | 10:48 PM
Use your tongue, it's more sensitive and will be more accurate.
Old Oct 18, 2008 | 02:23 PM
tds94probe's Avatar
ORIGINAL: CrAzyHuRRicAne
LMAO!!!!!! NICE!
Really though, if you can put your hand on the pipe, the bikes most likely not running on that cylinder........correction......its not running on tht cylinder.
Old Oct 18, 2008 | 04:14 PM
hypeshipe's Avatar
check your connections. had the same problem when i put my carbs back in. turned out that i had jiggled one of the two ignition wires under the tank that provide spark so it kiled my spark for two of my cylinders
Old Oct 20, 2008 | 07:42 PM
It was a clogged jet, The bike is running sweet with under 4,000 original miles!
