From one problem to another
Old Apr 24, 2013 | 06:20 PM
Chefohboy's Avatar
subject should be from one problem to another. ok so I resolved the earlier problems, now for some reason one I changed the ignition coil on cylinder 1 the ignition coil on 3 stopd working. is this normal? should I have changed all 4? I had to change the coil in 1 due to the fact that it was not grasping the spark plug.
Old Apr 24, 2013 | 10:39 PM
backdoc's Avatar
There is a fine wire in the tip of the coil. Remove the rubber tip and use a sharp tip object to bend it out and it will grasp the end of the plug just fine.
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
vietladin
Dec 25, 2007 09:48 AM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
