Oil leak 929
Old Sep 9, 2008 | 08:16 AM
Marley5205's Avatar
Default Oil leak 929
I have an oil leak on my 11000mile 2000 929. The bike has never been down. The leak is exactly 6 inches in front of the center of the kickstand. I noticed it about two weeks ago on the mat of the fairing.
I bought the bike used about one month ago . When I noticed the leak I wasn't sure if it had been there or if it was new. I am pretty sure it is new... After a 160 mile ride I am certain it is still dripping very slowly. However, I can't figure out where the oil is leaking from. I took off the lower fairing and looked up but couldn't seem to find the source.
I have a few pics if someone will share the easiest way to post 2 pics on this website.
I just bought the bike and don't know a ton about what is what in the engine.
Does anyone have any advice?
Old Sep 9, 2008 | 09:32 AM
pixel 6's Avatar
Default RE: Oil leak 929
929 bills... 929 skills...
Check out the oil my 929 spills..
Lol
Yeah, Take the plastics back off and clean the area with Simple Green or brake cleaner. Keep the plastics off, turn it over and you should be able to find the source. If you're lucky it's coming from the stator cover gasket, which is a cheap and simple fix.
Easiest way to get pics up, is to go here: http://www.imageshack.us/ upload the pic from your computer. Then click on the little picture icon in the fast reply toolbox section of this thread... it'll say: http://... simply put in the direct link you get for your picture at image shack.
Hope I helped.
- Pixel -
Bike may have gone down before you bought it and broke something.
After I got mine home, found an oil leak coming from the stator, went to change the gasket, and a 2" piece of the engine block came off that the dude had siliconed in place. Had to get it welded... Still leaks a bit on me... meh.
- Pixel -
Old Sep 9, 2008 | 11:59 AM
Marley5205's Avatar
The silver part centered in the pic is where the leaking is occuring.
This is the area with the oil leaking. The brown spot up and left of center is oil
This is the area clean- different angle
Old Sep 9, 2008 | 01:27 PM
HAVOC's Avatar
you really need to post larger pictures man
Old Sep 9, 2008 | 01:33 PM
Marley5205's Avatar
Sorry I am new to this pic stuff.
Anyway, I think I figured it out. The fluid is coolant not oil- I was confused because the fluid was dirty and shiny on my finger like oil... My bad
The coolant is draining out of a small overflow hole. It makes sense since the overflow container is at the upper limit for coolant. It's simply draining...
The guy I bought the bike from overfilled it.
Thanks for the help
ko67
F2 Tech
Sep 20, 2011 10:47 AM
vegas_rebel
Aug 28, 2011 12:10 PM
graysonwittwer
Aug 17, 2011 05:40 PM
amir145
Sep 1, 2010 11:33 AM
airick
Apr 17, 2007 06:58 PM
