Need Help, Brake Light
Old Jun 28, 2008 | 06:18 PM
scottiesan20000's Avatar
Default Need Help, Brake Light
I have a brake light problem. When I turn the ignition on, my brake light comes on and stays on. Pressing rear brake lever or front brake lever doesn't change it. What's causing this?????
Old Jun 28, 2008 | 06:26 PM
bignibb's Avatar
Permanent ROTM Nominee
Default RE: Need Help, Brake Light
maybe one of your brake light triggering switches are stuck?
Old Jun 28, 2008 | 06:36 PM
thanx for the quick response. are the triggering switches something I can get to/reach easily? Or should I just take it to the shop?
Old Jun 28, 2008 | 08:03 PM
Dizzymofo's Avatar
There's one right behind the rear brake pedal. Mine is on all the tire too
Old Jun 28, 2008 | 08:04 PM
bignibb's Avatar
well the only one I actually looked at is the one on the foot control because I don't have that one on my bike.
its the thing with the spring on it on the foot control.
Old Jun 28, 2008 | 08:14 PM
I'll go check it now....Thanx!!!!!
Old Jun 28, 2008 | 09:02 PM
I can reach the switch I think....I moved it around a bit, but nothing changed. Thanx guys, but I may have to take to the shop[:@]
Old Jun 28, 2008 | 09:17 PM
pixel 6's Avatar
The censor for the foot brake is conected to the rear brake lever, via a spring. You can unthread ie. loosten it and the brake light will go back off. Loosten it enough that the light doesn't chatter when you go over bumps or rough roads and you're set.
Easy Breezy.
Old Jun 28, 2008 | 09:37 PM
Dude!!!! That work!!!! ur freakin' awesome, Thanx!!!!!!!
dohc97
Apr 12, 2013 07:54 PM
phillycbr
Sep 2, 2009 10:35 PM
Hayden06F4i
Jun 17, 2008 09:50 AM
FLYOU
Jul 13, 2007 08:12 PM
mini bagels
Sep 4, 2006 04:31 PM
