Brake light doesn't work with front brake
Old Aug 26, 2009 | 12:19 AM
phillycbr's Avatar
Default Brake light doesn't work with front brake
Okay I have a one piece intergrated tail light and when I squeeze the front broke the brake light doesn't come on but when I press on the rear brake it does. Not really a big deal but a nuisance.
Thanks.
Old Aug 31, 2009 | 08:59 AM
emefef's Avatar
Default Problem has to be at the front
You already know the light works. Check the switch at the front brake lever. Disconnect it, and use a wire as a jumper across the terminals in the wiring harness. If that works, the problem is in the switch, or you didn't have a good connection. Clean it and try again. If that doesn't work, the problem is further along the harness.
9 times out 10 - maybe even 99 out of 100 - it's the fr brake switch or the connection to it.
Old Sep 2, 2009 | 06:48 AM
limpy88's Avatar
no brake light is a hugh deal. you could get rear ended. i saw scooter get hit for that very reason yesterday. and my friend in highschool got her 65 mustang to look like a accordin for no brake lights. but like previously said check the switch or the wires going to it.
Old Sep 2, 2009 | 09:39 AM
iHeartMyCBR's Avatar
Default directions to replace the switch?
I have the same problem -- is this a CBR weakness? Anyway, once you figure out your switch doesn't work, is it hard to replace? Any advice for newbies? Clymer and I seem to speak different languages...
Old Sep 2, 2009 | 10:41 AM
emefef's Avatar
Default Not difficult
You may have to loosen the control assembly on the handlebar and rotate it a bit just to make the switch more accessible. Changing the switch itself isn't difficult.
Old Sep 2, 2009 | 10:35 PM
limpy88's Avatar
it is one phillip head screw and 2 slip-on connectors. working a computer is more difficult. it is a mechanical switch. if it moves it will were out. it's a weakness of anything that moves. it a mantience issus not a problem.
jajgarcia
Jul 24, 2011 11:34 AM
jam0837
Apr 6, 2010 04:49 AM
Hornet55
Sep 23, 2009 03:13 PM
FLYOU
Jul 13, 2007 08:12 PM
aeroworks
Feb 23, 2006 01:21 PM
