brake light issue only with front brake
Old Apr 5, 2010 | 04:15 PM
jam0837's Avatar
Default brake light issue only with front brake
I ran into this issue yesterday. When I press the front brake the brake lights dont turn on. When i press the back brake the light turns on just fine. all the cables are plugged into the switch and it make a clicking noise when i press the break like it should. I cant think of anything else it could be. I also checked the fuses and they were fine. Any input would help. thanks
Old Apr 5, 2010 | 10:07 PM
vangill's Avatar
July 2010 ROTM
your wires r prolly broken somewhere then, or the switch in the front is back, get a voltmeter and test to see if there is power when u pull in the brake lever, that will tell u if the switch is good or not, if it is, you have a wire broke somewhere.
Old Apr 6, 2010 | 04:49 AM
Zero1080's Avatar
^What he said.
Hornet55
Sep 23, 2009 03:13 PM
phillycbr
Sep 2, 2009 10:35 PM
FLYOU
Jul 13, 2007 08:12 PM
JAYSONE
Apr 18, 2007 01:39 AM
aeroworks
Feb 23, 2006 01:21 PM
