could it be my chain??????
Old Aug 17, 2007 | 07:53 PM
sandtown929's Avatar
Default could it be my chain??????
my 01 929 is making a wierd noise. after about 10 mins of riding it makes this noise by the front sprocket. its an on and off kinda noise. hard to explain. just wanted to know if anyone had any idea what this noise could be. thanx.
Old Aug 18, 2007 | 02:07 AM
rmr1923's Avatar
Default RE: could it be my chain??????
i think i know the noise you're talking about. i posted here about it a while back and it was hard to explain it because it's not something that's easily compared to anything else i could think of. but needless to say, i adjusted the chain (it had too much slack) and the noise went away completely. it only happened while decelerating though. does yours make the noise constantly? if so, check your chain's freeplay. if it's loose then tighten it up to within Honda's recommended specs. if it still does it, you might have to replace the chain.
Old Aug 18, 2007 | 10:32 AM
yea the noise is there the whole time the bike is moving. my chain is to the point where when i tighten it one spot is tight then i move my bike forward then the chain is loose. ive got a 520 kit on it would that make any difference?
Old Aug 18, 2007 | 12:06 PM
TeeSnob's Avatar
my 929 makes a weirdnoise from the chain and engine, i took all my fairings off expect the front headlight fairing cuz it madeloose noise when i hit a bump.
im not really tripping about the noise..as long as my bike runs!!!
Old Aug 18, 2007 | 12:17 PM
rmr1923's Avatar
ORIGINAL: sandtown929
sounds like it's time for a new chain. hopefully that will get rid of the noise, and you certainly don't want to ignore it because any abnormal noise is a sign that bad things will likely follow (in most cases).
Old Aug 18, 2007 | 02:27 PM
ApexClipper's Avatar
Assuming your chain is clean andwell lubed and you're getting those tight/loose sections in the chain it's definetely time to replace it. May or may not be the noise you're experiencing but I'd start there.
Old Aug 18, 2007 | 07:03 PM
thanx for the info. i just wanted to c if anyone else had this kind of noise.
Old Aug 19, 2007 | 06:26 PM
mikey1297's Avatar
what does your chain look like? does it look like it needs replaceing? take the cover off and check the tightness of of your front sprocket i have seen the come loose before if your chain doesnt need replaceing why spend the $125 on a new one and still have the problem, and how many miles are on the chain?
davedude44
Jun 28, 2012 12:22 PM
TheHeggi
Aug 11, 2010 04:58 PM
Perranomous
Apr 19, 2009 03:04 AM
crookedeyemotocross
May 4, 2006 10:14 AM
