929rr odd start problem
Old 07-17-2014, 09:47 AM
frontwheellifted87's Avatar
Default 929rr odd start problem
My 01 929rr is giving me problems. When I turn key fuel pump primes an fuel pressure is at 53 psi. If I put a shot of starting Fluid in it spits like it wants to. Now I pulled harness. Going over everything. An ad harness sitting out side of the frame had injector pulse but no spark.
I've check all plugs cleaned them double checked all grounds unwrapped all the harness an everything looks good.
One min I got spark then next min I got injectors. Ecu is good tested in buddys bike n his ecu in my bike same results any idea?
Old 07-20-2014, 02:18 PM
mika_u's Avatar
Sept 2014 ROTM
Check everything that could prevent it from getting the spark. Engine kill switch, side stand switch, engine stop relay and the relay that stops the engine when the bike falls down comes. These come first to mind. And the lock wiring and ignition switch on the right clip-on.
USMC NVP
12-29-2012 07:58 AM
Hondafan7
12-08-2012 02:54 PM
NineTwoNineRR01
08-06-2007 10:06 AM
MorphiX82
04-24-2006 06:52 PM
mctonyb
05-20-2005 07:53 PM
Quick Reply: 929rr odd start problem
