01 929rr wont start :(
Old 11-21-2012, 07:18 PM
Hondafan7's Avatar
Default 01 929rr wont start :(
I bought this bike with all the plastics stripped off it.. it has the 954 motor on it also.... I put the ground on it and got a key for it and it wont start.... the fuel pump is kicking on i can hear it and it has fuel press. at the rail... When i crank it over it doesnt even try to start... i tried spraying a little bit of fuel into the top of the carbs when cranking it and it will try to start once or twice but just wont start.... CAN ANYONE HELP ME ON WHAT TO DO? i dont want to sent it to a shop if i dont have too...
Old 11-21-2012, 07:26 PM
74demon's Avatar
The bike doesn't have carbs, its fuel injected. Sounds like its not getting gas. Are the injectors spraying?
Old 11-22-2012, 08:48 AM
Hondafan7's Avatar
I checked and there is fuel pressure at the rail, but like i said when i sprayed fuel into the top of the butterflys it putted once or twice like it was gonna start but didnt... i checked and there is power to the coils.... i also forgot to say it has a 954 motor on it...
Old 11-22-2012, 09:46 AM
74demon's Avatar
You can have all the pressure in the world, but unless the injectors are opening, the fuel wont be delivered to where it needs to be. You really need to see if they have signal to work.
Old 11-22-2012, 09:57 AM
Hondafan7's Avatar
i also just noticed that the two breather tubes on the left side of the tank are not connected anywhere....
Old 11-22-2012, 11:26 AM
74demon's Avatar
That is not the source of the starting issue.
Old 11-22-2012, 07:00 PM
Hondafan7's Avatar
hmmm what next? i checked and the injectors are getting power, the coils are getting power... but even when i spray fuel in the butterfly's it only put... you would think as long as i keep spraying fuel in there it would stay running right?
Old 11-22-2012, 07:27 PM
74demon's Avatar
They have power, but do they have the ground signal from the ecu? Each should have a pulse signal, or no they won't work. Have you lifted up the fuel rail to see if they spray?
Old 11-23-2012, 08:47 PM
john87's Avatar
battery dude i had the same problem. either get a new one or slow charge your for 12 hours
Old 11-26-2012, 07:45 AM
sj66's Avatar
Pull the earth wires, clean and put back on
They are just in front of the back wheel
Easy to try.
Quick Reply: 01 929rr wont start :(
