929rr Wiring Problem
Old Apr 19, 2006 | 02:55 AM
MorphiX82's Avatar
Default 929rr Wiring Problem
hey everyone, i have a 2000 929rr and im having a little bit of a problem. When i turn my key on my headlight barely comes on and my rear blinkers are frozen on. all the fuses are good in the fuse box. ive checked all the grounds and its still stuck on. Any ideas on what to check next. TJW
Old Apr 19, 2006 | 04:59 PM
joe200803's Avatar
Default RE: 929rr Wiring Problem
Hello morphi has the bike got an alarm? and what happens when you start the bike does it all work proper? if you have an alarm it may be something to look at and if it works fine when you start don't worry about it all the best.Joe
Old Apr 19, 2006 | 06:16 PM
joe200803's Avatar
Hi Morphi got something eles for ya do the front blinkers function as running lights so they have dual filament bulbs so do the rear blinkers have the wrong bulbs in try that buddie.Joe
Old Apr 19, 2006 | 06:53 PM
MorphiX82's Avatar
No the blinkers are singal. they do not blink at all becuase they are stuck on constatly. i try to turn the blinkers on but they do nothing and the indicator dosent even come on in the display. The Headlight dosent even switch from high beam to low beam when i hit the switch. I am going to take the control for that apart tonight to see if there might be a loose connection in the controls.
Old Apr 19, 2006 | 07:11 PM
QuinC's Avatar
when my headlights stoped working it was because of the connector that they connect into had burned up the headlight wire.
Old Apr 20, 2006 | 11:09 AM
MorphiX82's Avatar
new news on the wiring issue. If you take the headlight fuse out it will not cause the blinkers to freeze and everything works correctly. when you plug the fuse back in blinkers freeze again and will not blink. then i got a little bit deeper and found out that if you unhook the set of wires that go to the starter and the kill switch the blinkers will work correctly and the headlight will not even come on. Dont want to have to take it to a mechanic but looking that way. going to get a test light tonight and see what i cant find out.
Old Apr 20, 2006 | 04:33 PM
joe200803's Avatar
Good luck with the test lamp and let us know how you get on, all the best.Joe
Old Apr 21, 2006 | 07:54 PM
MorphiX82's Avatar
Well guessy guessy what! There is a end connecter above your headlight that is just like a terminator(ends the cables and goes no where.) When i was taking the bike apart i hit this and the light flickered. I had a loose connection with a wire shorting out in there. I fixed that but and with doing that i lost my gauges. I popped a fuse and when i replaced it everything was good to go again. Hoo Rah!!!
Old Apr 24, 2006 | 04:42 PM
joe200803's Avatar
Thats good to know just in case all the best man.Joe
Old Apr 24, 2006 | 06:52 PM
QuinC's Avatar
congrats!!
frontwheellifted87
Jul 20, 2014 02:18 PM
JerisG24
F2 Tech
Apr 1, 2010 06:08 PM
Mista Cy
Feb 5, 2010 09:36 PM
TrnsferErr
Jun 4, 2006 12:31 PM
mctonyb
May 20, 2005 07:53 PM
