929rr odd start problem
My 01 929rr is giving me problems. When I turn key fuel pump primes an fuel pressure is at 53 psi. If I put a shot of starting Fluid in it spits like it wants to. Now I pulled harness. Going over everything. An ad harness sitting out side of the frame had injector pulse but no spark.
I've check all plugs cleaned them double checked all grounds unwrapped all the harness an everything looks good.
One min I got spark then next min I got injectors. Ecu is good tested in buddys bike n his ecu in my bike same results any idea?
Check everything that could prevent it from getting the spark. Engine kill switch, side stand switch, engine stop relay and the relay that stops the engine when the bike falls down comes. These come first to mind. And the lock wiring and ignition switch on the right clip-on.
