temp gauge not working
Old Apr 22, 2007 | 11:09 PM
HAVOC's Avatar
Default temp gauge not working
whats up everyone , got a quick question. my temp gauge isnt working right now. the fan comes on and everything but the gauge just doesnt move. now right now my speedo and odometer doesnt work either. i know thats because i dont have the speedometer sensor pluged in , could that be the reason why the temp doesnt work or is there something else i should be looking @ ? thanks in advance
Old Apr 23, 2007 | 03:00 AM
johnnyh's Avatar
Default RE: temp gauge not working
There's a conector under the tank that has four wires;(speed sensor,oil pressure,neutral sensor and water temp), check that conection or simplyremove the wire from the temp sensor and by grouding it the needle should go up, if it doesn't the gauge is bad. If it does its your sensor. The sensor is located under the thermostat housing on the head. I hope that helps. Johnny
Old Apr 23, 2007 | 04:14 AM
HAVOC's Avatar
the speed sensor that connectsby the front gear , i dont have that piece at all . then i know it plugs into a connector under the tank. i guess what im curious about is it all hooked up off one connector? because my neautral sensor works, my oil light isnt on (so im assuming the oil pressure is being read good), im totally missing the speedometer sensor, im just not sure how the temp sensor connects.
hope im not makign things too confusing for those who are trying to help [&:]
Old Apr 23, 2007 | 04:55 PM
johnnyh's Avatar
You Know what , I was wrong the seed sensor is a single connection to one connector. I just converted my 94 to a 96 front end and I had to change my gauges to fit the upper fairing and mainstay bracket so my old gauges were manuel on the speedometer. Changing the gauges to a 96 went to electrical speedometer so I had to change wiring harrness as well and I got the sprocket cover with the speed sensor to make everything work. The connections are under the tank but the speed sensor connection is by itself with tree wires. When I changed to the 96 I had to iliminate my fuel pump because the 96 comes withou the pump. I hpoe this helps. Johnny
Old Apr 24, 2007 | 04:33 AM
HAVOC's Avatar
well i knew the 96 gauges switched to electric and i i know where the connector fo rthe speed sensor is. just curious as to how the temp gauge functions. i guess when i buy my speed sensor ill plug it in and hope for the best haha
Old Apr 27, 2007 | 10:37 AM
chrisf's Avatar
On my 98, the temp sensor works fine even when the speedo is not connected. On mine, it is a small bullet connector to the water temp sensor in the head. Make sure the wire is connected. I've never heard of a water temp sensor going bad.
--Chris
Old Apr 27, 2007 | 07:08 PM
HAVOC's Avatar
thanks ill check that connection tonight
Old Apr 30, 2007 | 03:34 AM
900nos's Avatar
heres one for you guys,,
odometer died today... speedometer still works,,all electrical.
96 cbr 900rr
Old May 2, 2007 | 04:45 PM
HAVOC's Avatar
i was looking behind my gauge cluster yesterday and what appears to be a relay and it looks like the wires from the temp gauge go into it, am i looking @ that correctly or am i just a dumb *** and seeing something else.
NoleLife561
May 10, 2012 10:14 PM
72tx340
Oct 12, 2011 06:45 PM
Mike091
Feb 15, 2010 07:58 PM
HAVOC
Apr 23, 2007 05:03 PM
mervyn
Nov 10, 2006 09:11 PM
